Car Using Oil
Old Jul 29, 2006 | 12:55 PM
mike2244's Avatar
Default Car Using Oil
After My Le1 Install I Installed A 52 Mm Bbk Throttle Body And Full Bolt Ons. I Noticed That My Car Started Using Oil. Very Strange Cause My Car Don't Smoke Or Leak Oil. I Pulled Off The Hose That Runs From The Valve Cover To The Throttle Body And Seen Oil Dripping From The Throttle Body Port. Is This Where My Oil Is Going In To The Intake. If So How Do I Fix This Problem. Any Advice Would Be Helpful.
Old Jul 29, 2006 | 01:32 PM
buffman's Avatar
Most likely thats where the oil is going if the valve stem seals are good and you have a healthy running engine. Most people throw a breather on the pass side valve cover and cap off the TB port for the hose.
