Hey Got A Question Hope Someone Can Answer Quick
Old Aug 3, 2006 | 12:18 AM
CULATR's Avatar
Default Hey Got A Question Hope Someone Can Answer Quick
Will 8mm taylor wires that go with the slp mid length headers fit jet hot Lt's ? Reason im asking found a good deal on a set of wires and was wondering if they would fit my lt's and be ok ??? any help i appreciate it alot thanks........
Old Aug 3, 2006 | 08:17 AM
96SCTA's Avatar
Yes they should work for you. As long ase you are not using the over the valve cover wire tie up method. Because then i think they will be to short
Old Aug 3, 2006 | 10:40 PM
CULATR's Avatar
K thanks for the info......
