rear brakes help!
Old Aug 6, 2006 | 02:08 PM
Ralls's Avatar
Default rear brakes help!
Ok, my car is currently jacked up and I'm trying to change my rear pads. I got the pads off but how the hell do I return the piston. I read somewere about screwing something in. And I noticed you can screw in something with an allen wrench. Do I loosen that up? Need help!
Old Aug 6, 2006 | 02:35 PM
urbanhunter44's Avatar
You talking about compressing it? open your bleeder valve and just compress it with a standard piston compressor. That's how I've done it on both of my LT1s.
Make sure to open the bleeder valve (it'll squirt as you compress) otherwise it'll be harder than ****/impossible to compress and if you DO compress it, you could **** up the ABS system.
