obd2 swap
The reason i was asking how fast is most have the problem around 17 and faster 60 FT times. an if they are running a TH400 they probably had the problem
I have cars in the 9s and 10s on my 4L60Es and Ed Write one of the oldest and best around. He posts here. If you search his name you should come up with some thing.
What happens is there is a table that sets the "No VSS" code if stall is higher then "X" and there is no VSS signal
Ed was telling me Yank and Edge converters seem to have the biggest issues although I have seen it bad with Fuddle converters and also on TCI and PI converters.
I run a transmission shop durring the day and Speed Secrets at night so I see alot of them
As far as that table goes the only VSS related thing I found was "Vss Diag. Enable Min RPM" which mine is at 3,000 ... this was found in the ECM constants. I do most of my own tuning, so thats why I was wondering! There has to be a way to tune around this!
the only thing i hear bad is that he tunes it and when he does you cannot ever ahve any1 else tune it again. which aint a bad problem but i hear sometimes he can be hard to get ahold of?
This (and the fact that it annoyed the heck out of me with its looseness) is why I sent my converter back to Yank and had them restall it DOWN to "as tight as you can get it". I shipped a ST3500, it came back as a SY3000. So far it does seem tighter, but I haven't driven the car more than backing it in/out of my shop. Need to do a bunch of work before I can take it to the streets.
Ken @ Carputing sent me an attempted fix a long time ago, but it didn't work. I have Datamaster logs showing me going from 3mph to 140 mph in 1 frame of data. The PCM don't like that.
At this point, I don't want to go back to an OBDII PCM either, so if this Yank starts acting up on me, I'll sell it and go back to a full size 2400 converter (hey Ellis, is Pac Trans still around?
). I sure hope it works though, I'm about $1000 in to it at this point (original purchase plus rebuild).Oh, and Ed's web site is fastchip dot com
i cant believe that you have to go through this trouble...from what i understand its s simple loss of a signal from the tranny on hard launching that does this...so why cant you replace a sensor? or rewire somethin to eliminate it?
id really like some1 to say i feel your pain lemme help ya out....
that a great deal but i dont have 350 more or 550 to fix this....
and i dont think a dyno tune on my 306 is worth it, ill wait till i have a custom cam..
cause on mine i keep over revving 2-3 shifts and my tuner and i tried soo many things to try and fix it but wont work. This keeps burning out my 2-3 clutches.
3200 stall here.
http://www.cahallperformancetransmissions.com
he will build you an almost undestructable overdrive gm tranny
