lt1 waterpump?
Old Aug 14, 2006 | 07:32 AM
gpss02's Avatar
Default lt1 waterpump?
ok, my waterpump started leaking on me sometime this weekend, and was just wandering how much of a pain it is to change, that way i know what i'm looking at. the car is my only driveable car right now so i have to try and get it done in one evening in order to make it to work the next day.
Old Aug 14, 2006 | 07:46 AM
aggiez28's Avatar
one evening is enough time. i have an extra pump. pm me if you need one
Old Aug 14, 2006 | 07:49 AM
Camaro_freak's Avatar
It's not too bad to change. The hardest part for me was removing the stuck on hoses. For those I just took a small flat head screwdriver and poked it in the end to pry the rubber away from the metal. It didn't ruin the hoses or anything.
Old Aug 14, 2006 | 09:33 AM
Dr. Teeth's Avatar
I've removed and installed mine 4 times in this past week because I am a moron. It's not so bad, just make sure you have the gasket surfaces clean and removing the fans/radiator makes the job a lot easier, believe it or not. This whole job takes me about 2 hours if I take my time and do it right.
Old Aug 14, 2006 | 11:30 AM
gpss02's Avatar
Default lt1 water pump
alright, thanks for the input i'm gonna change it this afternoon, being my only driver. is there anything i need to pay special attention to while reinstalling it? this is my first time working on this car, i've mostly working on mustangs before. and thanks for the offer aggiez28, but i gotta get it done as soon as possible, so i'm gonna just get a new one this afternoon. but thanks for the input guys, appreciate it,
mike
Old Aug 14, 2006 | 11:31 AM
Captainofiron's Avatar
MAKE SURE the drain the coolant before you take off the water pump, or else your Opti will be taking a bath
Old Aug 14, 2006 | 12:33 PM
gpss02's Avatar
yeah, if it hasn't already, the water is pouring out like crazy wherever its leaking. i put water in it so i could go grad something for lunch, and it was hot by the time i got back, and still pouring out water..and i was only gone for like ten mins.
Old Aug 14, 2006 | 07:03 PM
Cammd95Z's Avatar
The more you drive it the better chance you have of ruining your opti, and you dont wanna replace that 2 weeks down the line cause ur new water pump will have to come right back off
Old Aug 15, 2006 | 07:18 AM
gpss02's Avatar
well i got it changed out last night,but when it was all back together i checked for leaks and stuff, and to my suprise the damn water pump (new one) had a crack in it on the underside and was leaking just as bad as the old one, so thats got me really pissed off since i have to do it all over again this afternoon. only one good thing about it this time, i know what all has to come off to get to the water pump now, so it should be a lil quicker today.
Old Aug 15, 2006 | 11:45 AM
slow96z's Avatar
You should also pull the vent lines from the bottom of your opti and blast some compressed air through it if you have it available.
Old Aug 15, 2006 | 12:22 PM
gpss02's Avatar
where does the vent line from the opti go?? i have some line coming from the intake that was hanging down to the bottom of the car between the motor and the radiator that wasn't hooked to anything, would that possibly go to the opti? i'll look today, but when i bought the car the guy said it didn't have a vented opti, so i don't know, i'll check it out when i'm back in there this afternoon.
Old Aug 15, 2006 | 01:00 PM
Dr. Teeth's Avatar
One should go to the intake and be (+) for vacuum, the other should go to a fresh air source, mine goes up to the duct between the MAF and the TB. there was a little blue plastic pipe piece that mine hooked up to.
Good luck. I get to take mine apart tonight for the 5th time, finally figured out what was wrong.....
Old Aug 15, 2006 | 02:32 PM
gpss02's Avatar
Default vent
yeah i think i found the one for the intake part, but have never seen a piece to the duct, might check it out. is there a such thin as a non-vented opti?
Old Aug 15, 2006 | 03:37 PM
Dr. Teeth's Avatar
Yes, I am not sure when they started them though. If you pop the Opti off you can see where the fresh air one goes to. It's actually on the right side of the unit, lower like at 5 oclock, right behind the balancer. That one should go to the fresh air part, although my expertise ends with the 96 model year, because that's what I have.
b
Old Aug 16, 2006 | 07:57 AM
gpss02's Avatar
yea i found it yesterday while under there. the fresh air is hooked up, now where does the line from the intake hook up on the opti? does it need to be hook up or will it hurt it not being connected?
Old Aug 16, 2006 | 08:26 AM
Dr. Teeth's Avatar
Closer to the motor on the back of the Opti there should be another vacuum tube hookup, although this one should be metal. That one goes to the intake manifold. It's on the metal casting portion of the opti and is closer to the motor and the input shaft. It also takes a smaller size vacuum tube.
Old Aug 25, 2006 | 10:57 AM
burt_renolds's Avatar
Default lower left hose running off waterpump
This is a little off the subject, but still close enough I hope; what is the line running off of the bottome left side of the LT1 waterpump? Where does it run to? Last night my line blew some how and I looked at it this morning in the day light and I can just barely see down in there because there`s hardly any space, but I can see that the line broke or came apart at like this metal piece. Is there supposed to be a clamp there or something? I can almost push the two pieces of hose together like one end fits inside the other. Does that make sense? Does anyone have any insight for me? LOL I want to fix it myself because I just paid to have it towed home.
Does anyone know?
Old Aug 25, 2006 | 11:54 AM
blind527's Avatar
Did you guys notice a gain in performance and power with the new water pumps?
Old Aug 25, 2006 | 04:17 PM
Sinister95Z's Avatar
Only if you went to a electric water pump would you notice a difference.
Old Aug 25, 2006 | 05:44 PM
edlt1's Avatar
It doesn't take that long. It can be a bitch though.
Once I pulled my a/c it got a lot easier to change out stuff like that
