Turbo
Old Aug 15, 2006 | 07:39 PM
onebadblackz's Avatar
Default Turbo
anyone here turbo fans??
Old Aug 15, 2006 | 07:57 PM
Dragframe's Avatar
of course... there are lots..
Old Aug 15, 2006 | 08:30 PM
well I found a T3 with the blowoff valve, wastegate, and front mount intercooler for 1549.00
Old Aug 15, 2006 | 08:31 PM
Dragframe's Avatar
t3 is for like a 1.8 liter 4 banger...
Old Aug 15, 2006 | 08:52 PM
formula355LT1's Avatar
i want STS
Old Aug 15, 2006 | 09:13 PM
Dragframe's Avatar
Originally Posted by formula355LT1
i want STS
If i was you i would change that to PTS...
Old Aug 15, 2006 | 09:37 PM
so it wouldn't do me any good
Old Aug 16, 2006 | 09:17 AM
RealQuick's Avatar
Not unless you have two of them.
Old Aug 16, 2006 | 10:04 AM
NemeSS's Avatar
did u find a kit or just the parts?
if u found a kit, then go for it. buy and install it, there are t3/t4 hybrid turbos u can use tht are sort of cheap
an example, on my diy turbo on my lt1, (this was back in 97-98)
i built a turbo system with stock manifolds,ported and mild steel, ex. plumbing
with a Cummins turbo off a 95 5.9 Dodge Ram diesel truck and a A/A intercooler made from 2 supra cores and fabbed end tanks. for fuel i used
an fmu and larger injectors.
id say the car made about 450-475+hp
i would see up to 9psi, and even up to 12psi, and it would hold it from 2300-5500-5700 rpm but the opti couldnt keep up after that.
this was on an otherwise stock everything lt1 95 camaro,
that Cummins turbo is a t3/t4 hybrid and it works very well and makes good power and spools very quick on a 350 ci engine, i have even made 775+ rwhp with 2 of these turbos on a 383 SBC for another friends 3rd gen camaro
on pump gas,
so they have some potential, but they are not race units
great for street and some race use, spool quick
on another note, the turbo does not know it is a diesel turbo or a gas turbo nor does it care, it matters yes,but not really unless its a dedicated racer, but it works for the price had. imo
ps if i remeber correctly, it cost +/- than 1500$ to do the kit, with me doing all the fab and parts, turbo and intercoolers came from wrecked cars
but were in working order.
gl
Old Aug 16, 2006 | 10:08 AM
NemeSS's Avatar
ps also had 2 walbro intank pumps
Old Aug 16, 2006 | 11:54 AM
Camaro94SS's Avatar
So a 4 cylinder turbo wouldnt do these cars any good eh? Not even the ones that are on the WRX STi's? or the Evo's? Those are pretty cheap $$$ i beleive....
Also what do you think the max PSI could be reached and used often on a stock LT1?
Old Aug 16, 2006 | 12:12 PM
DrTurbo's Avatar
LS1TECH Sponsor
If you want a cheaper unit that will make decent power, talk to Jose.....the number is in the sig below
Old Aug 16, 2006 | 12:40 PM
NemeSS's Avatar
the stock turbos on those cars are weak for even them,
they all upgrade to larger units, on a 350 ci motor they would be of no use,not even using 2
stock lt1 6-9psi with a/a intercooler, 93 octane, sounds bout right
Old Aug 16, 2006 | 02:46 PM
I found that all in a kit www.cheapturbos.com under turbo packages
Old Aug 16, 2006 | 02:56 PM
NemeSS's Avatar
it seems like they are "upgrade" packages for turbo hondas and not kits,
i dont think u could use em
Old Aug 16, 2006 | 04:21 PM
I could just have to build a mount and get headers and stuff like that
Old Aug 16, 2006 | 05:37 PM
Dragframe's Avatar
well dood.. those turbos are so small they would become a restriction in the exhaust... and choke power instead of helping...
Old Aug 16, 2006 | 05:42 PM
well I decides to just get a supercharger and LT's
Old Aug 16, 2006 | 05:55 PM
NemeSS's Avatar
not a diy guy huh?
sc works too, got an old p600b lying round, needs rebuild
looking for new home
Old Aug 16, 2006 | 05:58 PM
I can built the stuff to do it just no $ tight budget how much for the SC
