shift kit guys in here.
Old Aug 18, 2006 | 05:16 PM
LMz28's Avatar
i was gonna have the line pressure bumped up a little when i order the tune but now that i have this Tgo im not gonna have madz28 bump it up. im a complete newb when i comes to transmissions and shifting. how do you hold gears and manually shift?
Old Aug 18, 2006 | 09:36 PM
95FbFormula's Avatar
You hold the gears and manually shift buy putting the shifter in 1-2 or 3 jst like you would drive. If you dont see the 1st you need to get rid off the little plastic peice in there to acess it.
Old Aug 18, 2006 | 09:42 PM
LMz28's Avatar
****...i only have 2. could i get a center console cover with 1 on it and not have to do anything else? and until i get it can i just drive around with the cover off so i can get into it?
Old Aug 18, 2006 | 11:44 PM
No you dont need it there is a little nylon or plastic blocker under there to stop shifting into 1st just remove the top of the center console and you shold see it i think its white just cut it off and you can now acess 1st with no prob. There is an actuall detailed way to do this in a post around here if you need more info. Its pretty straight forward though.
Old Aug 19, 2006 | 12:37 AM
LMz28's Avatar
thanks man.
Old Aug 19, 2006 | 01:22 AM
revtime's Avatar
If your serious about winning races you don't want the tranny shifting so hard it lays a good patch from first to second.
Is it fun when it does that? HELL yes, but its wasted power.
I used to have a 60E with the Trans Go kit and it would hit second hard. Too hard.
The Rossler TH400 I have in the car now does not chirp if I have the DRs on and just a barely audible chirp with street tires on. It still shifts hard but its not wasting the power.
Old Aug 19, 2006 | 05:06 PM
titter's Avatar
I have my line pressure adjusted pretty well in my 4L60E ... it shifts hard, and when I first got it back it would chirp very easily ... now I pulled back some pressure, and fine tuned it to the point where it chirps occasionally, but normally it is very low and hard to hear with the street tires.
