ported and polished lt heads
Old Aug 17, 2006 | 02:53 PM
gapp94vert's Avatar
Default ported and polished lt heads
has anyone run ported and polished lt1 heads? if so what cam if any did you run with them? what kind of numbers did you put up? were you satisfied?
Old Aug 17, 2006 | 02:58 PM
Tony Shepherd's Avatar
check out www.portpros.com
He has some great packages that put out some awsome #'s. I am very satisfied with his stuff.
Old Aug 17, 2006 | 03:49 PM
95_Firehawk_Dude's Avatar
Could always talk to Lloyd. He knows what's up.
EPortWorks
Old Aug 17, 2006 | 05:18 PM
Old SStroker's Avatar
Check this thread:
https://ls1tech.com/forums/lt1-lt4-modifications/558911-best-heads-cam-package.html
Also try a search on the people/companies in those links that were suggested to you.
Old Aug 17, 2006 | 05:25 PM
gapp94vert's Avatar
i was just wondering if anyone in this forum ever used them just wanted to know what experince they had with them if it was good or bad
Old Aug 17, 2006 | 05:52 PM
aggiez28's Avatar
lol someones got alot of learning to do.
tons of people have ported heads. some are good some are not
Old Aug 17, 2006 | 05:59 PM
gapp94vert's Avatar
im talking about stock lt1 heads that are ported and polished not aftermarket heads ill say it again stock lt1 heads that got ported and polished
Old Aug 17, 2006 | 06:40 PM
96capricemgr's Avatar
Most of us will actually recommend ported stock heads over aftermarket. People are FAR too quick to ASSume aftermarket means better. With the LT1 GM left a lot less room for improvement and some of the aftermarket crap is just basically converted gen1 stuff that might have been geat on a Gen1 but with the LT1 heads starting out pretty good few of the aftermarket offerings offer any bang for the buck.
www.advancedinduction.com is my choice and I am quite happy 12.6 at 106 last night at abut 4250lbs. from a daily driven Caprice. The guys with the LS1s are suprized by my whale with just an LT1.
Old Aug 17, 2006 | 06:44 PM
Built LT1's Avatar
Call Advanced Induction. 704-907-4341. Also, check out their website; they have ported intakes to match their head work.
Old Aug 17, 2006 | 10:34 PM
The "Search" function is your friend. Read some of these threads:
https://ls1tech.com/forums/search.php?searchid=3788916
https://ls1tech.com/forums/search.php?searchid=3788909
https://ls1tech.com/forums/search.php?searchid=3788921
Old Aug 18, 2006 | 09:24 AM
aggiez28's Avatar
there are good aftermarket heads. if your going to make a statement like that you may as well say which ones are bad and which ones are good.
AFR makes some good heads, i would get them ported elsewhere though
Old Aug 18, 2006 | 02:23 PM
gapp94vert's Avatar
thanks 96 caprice your telling me what i want to hear im trying to go cheap with this car just somthing for the street so i asked around locally and my guy that does all my work found a set that he did for 650 so im gonna buy them
Old Aug 18, 2006 | 03:24 PM
scrmnws6's Avatar
LE2 heads and cam. 400rwhp, could've been more but I did not degree the cam.
Old Aug 18, 2006 | 09:32 PM
I would run LT4s or Trickflows long before AFRs. IMO AFR is living off a reputation earned on the gen1 and has not kept up on the LT1, the guys that go fast with AFRs throw cubic dollars at the car, the guys that go often just as fast for a fraction the cost do so with GM castings. I would also NEVER bother with LT4s or Trickflows unported and not on a stock displacement motor either
Old Aug 18, 2006 | 10:05 PM
Speedy's Avatar
Good advice. He should get those heads flowbenched so he knows the numbers. It helps when you're choosing a cam to know what CFM the heads will flow.
Old Aug 19, 2006 | 10:59 AM
IMO cam to head matching is overrated. Even without a flow sheet we know a good ported LT1 head will be at or very near peak by .550 that is all you really need to know, then the cam should be setup to match the USAGE and rest of the vehicle.
