stall pcm question!!
Old Aug 17, 2006 | 07:32 PM
titter's Avatar
Default stall pcm question!!
ok here is one for the big boys! going through all the pcm tables in cats tuner i was looking at the tcc wot forced lock speed threshold vs gear vs tps ... now i will think this has something to do with how the stall locks and unlocks at wot correct? also in the tcc normal mode release/engage mph vs gear vs tps the 2nd 3rd and 4th are all maxxed out at 255 were as the tcc performanc mode release/engage mph vs gear vs tps only shows 3rd and 4th and it was the same lock/unlock mph as the tcc wot forced lock speed threshold vs gear vs tps. i always thought the z28 used the performance **** table, so i would imagine it uses the performance tcc engage/release as well right? i was curious what any of this should be set at? i mean it should eventually lock up at wot other wise it will be to lose and it will slip correct? someone school me on this subject!
Old Aug 18, 2006 | 09:36 PM
96capricemgr's Avatar
If you have a good converter you do not need/want to lock it at the strip. If doing open road racing like the SilverState then maybe but that is it. Locking a converter at WOT on the strip is a bandaid for an inefficient converter.
