LT4 Knock Module guys come on in
Old Aug 18, 2006 | 02:08 PM
ToxicFormula's Avatar
Default LT4 Knock Module guys come on in
Ok so I put in a LT4 KM and I think I noticed some improvements but I'm not sure if its all in my head. So I was wondering, all of you who have the LT4 KM, what improvements, if any, did you notice after installing it?
Old Aug 18, 2006 | 02:15 PM
slowmofo's Avatar
Installed mine when I did my cam change, so noticed a ton!!
Old Aug 18, 2006 | 02:17 PM
Honda Hunter's Avatar
I didnt notice sqat. I even used a datalogger and didnt notice anything different.
Old Aug 18, 2006 | 02:19 PM
Built LT1's Avatar
I did not notice anything different either when I put my first 383 in. However, it does not mean it did not work or benefit!
Old Aug 18, 2006 | 02:33 PM
I'm pretty sure it didnt do much of anything.
Old Aug 18, 2006 | 03:14 PM
96lt1m6's Avatar
ii did not notice anything which tells me i was not getting very much if any knock in the first place but its there and mods never seem to stop
Old Aug 18, 2006 | 03:44 PM
StealthFormula's Avatar
no different to me but I would understand if you felt a difference if you previously had knock and the lt4 km took care of it.
Old Aug 18, 2006 | 04:53 PM
I dont think it makes knock go away. It just changes what the computer does when it does detect knock. Hook up a scan tool like Freescan and check for knock. Then install the LT4KM and youll still see the same amount of knock. I'm guessing with it the computer does retard as much timing and bounces back quicker than without it.
Old Aug 18, 2006 | 05:28 PM
Ls1Bait's Avatar
The LT4 Knock sensor is better when you have Roller Rockers because the lt4 had them stock. False knock from valvetrain is less detected from the LT4 module and that seems to be why people switch.
Old Aug 19, 2006 | 09:34 AM
z_speedfreak's Avatar
nada lotta, wasnt expecting anything tho, its there to keep the engine from loosing power not to gain really
Old Aug 19, 2006 | 02:09 PM
NXSLT1's Avatar
Noticed a big difference. The car ran much smoother afterwards, it was sort of erattic due to the headers until I put the KM in.
Old Aug 20, 2006 | 02:45 AM
Camaro Fan's Avatar
I was getting 3-4 degrees of timing pulled out from a little knock being detecting around 4000-4500 rpm at WOT in mine. Started some time after the headers, I was kinda figuring it was false knock so I snagged a LT4KM. I've only datalogged it on a couple WOT runs after the LT4KM install but it seems to have eliminated the knock completely, hopefully that wasn't a fluke...
Old Sep 10, 2006 | 04:31 PM
C_Rules's Avatar
excuse me for being an idiot but what is knock?
Old Sep 10, 2006 | 07:26 PM
SShawn's Avatar
wheres a good place to buy one? i dont think my local shop carries em.
Old Sep 10, 2006 | 07:41 PM
87Lt1Monte's Avatar
Knock or Ping some people call it. Is a sign of detonation. The knock module "listens" for a destinct sound that knock makes and the lt4 improves over the lt1 because it is not as sensitive to other noises like headers, or exhaust. So say u change your headers and u notice through datalogging that u now see some KR "knock retard" which is what the computer does to reduce knock/detonation which in turn damages your engine. Knock is caused by running to much timing. Most of the time it has to do with the oct ane gas you run. When i changed mine i noticed little change with my 383 as well. but it did keep the KR down lower. I ordered mine from the internet somewhere cant remember
Old Sep 10, 2006 | 09:04 PM
UnitZ28's Avatar
try to find someone who works at a gm dealership... i got one for $25
Old Sep 10, 2006 | 09:06 PM
SShawn's Avatar
i work at a gm dealership...hmm
what year vettes came with LT4 and what was the engine code?
Old Sep 11, 2006 | 04:12 AM
MrCadillac's Avatar
96 vettes I think. a search around the interenet should locate one for about 25 bux.
Old Sep 11, 2006 | 12:57 PM
JOSE REBS's Avatar
Lt4 Came Only In All 96 6sp Vettes. Only 100 In 1997 Camaro Ss And 29 In 1997 Firehawk.
Old Sep 11, 2006 | 01:00 PM
Ill bet the 100 LT4 97 Camaros didnt get the KM.
