Help
Old Aug 20, 2006 | 07:46 PM
onebadblackz's Avatar
Default Help
went to kill my car just a min ago and couldn't kill it the key wouldn't come back so I had to kill it at the intake and then un hook the battery..... need help my key still in there
Old Aug 20, 2006 | 09:26 PM
anyone
Old Aug 21, 2006 | 11:31 AM
drpz28's Avatar
check out shbox.com the how to section has something in there about that
Old Aug 21, 2006 | 11:42 AM
Z48LT-1's Avatar
My wild guess: you've got an automatic and you can't get it into Park far enough for whatever is supposed to happen then to happen. Wiggle the stick. Good luck.
Old Aug 21, 2006 | 08:34 PM
did a complete transmission transplat from a 4L60E to a 700R4/4L60..... with a B&M quicksilver shifter......
Old Aug 22, 2006 | 07:40 AM
Z48LT-1's Avatar
Right. Isn't there a mechanical link between the tranny/shifter and the column that allows the key to turn when the tranny is in park, but not when it's not? I'm guessing that's out of kilter some how. Again, good luck.
Old Aug 22, 2006 | 11:47 AM
buttermantoast's Avatar
Sounds like maybe the ingnition switch on top the dash is shot and you cant pull the key back because its froze and the rod is stuck.
Old Aug 22, 2006 | 10:48 PM
how do I fix it can I pull the cylider out and cut the pin off
Old Aug 22, 2006 | 11:11 PM
transam5.7lt1's Avatar
There's a cable that runs from the shifter to the ignition switch(down at steering column), at the shifter it has a solenoid that allows shifting lever to move up and down on console when brake pedal is pressed. Now, at the same time brake pedal is pressed, it gives the key cylinder ease of movement through a lever/rod that runs internally on the steering column, this lever/rod moves forward as the key moves to the ON position. Same lever/rod moves your ignition switch(I mean the electrical part at bottom of steering column) sounds like it got stocked there at the switch... It did that to me except I got to turn off my car forcing the key towards me, and then couldn't get the key out, after messing around with the cylinder... key wouldn't even move forward enough on the ignition switch to start the car.... Replaced ignition switch and problem solved... bypassed VATS aslo while I was at it...
Old Aug 22, 2006 | 11:13 PM
Basically... just what buttermantoast just said
