TB bypass
Old Aug 22, 2006 | 01:16 AM
Revelation Z28's Avatar
Default TB bypass
i just got done doing it.
i used 3/8ths fuel line to plug up the TB ports i just looped it to connect to eachother. i hadda take the TPS off to have access to the input side of the TB coolant hose.
this is how i did it.. buti used no hose clamps and the plastic connector and RTV.
this way
what am i missing now? do i have to bleed the cooling system?
Old Aug 22, 2006 | 04:13 AM
95gt760's Avatar
hey thanks for that cool litle site its very helpful im think aboat doing this mod could you actualy feel more power
Old Aug 22, 2006 | 08:53 AM
nodnarb481's Avatar
you dont have to bleed the system but check your coolant level if you lost some and fill accordingly
Old Aug 22, 2006 | 11:43 AM
i lost maybe 1/4 pint.
Old Aug 22, 2006 | 06:02 PM
Bowtie Boy's Avatar
this is the way i did it...for your info and for people who want to do it.
I cut the short hose from the coolant line to the inlet of the TB completely off
I took the longest hose, from the TB outlet and looped it back to the coolant line. resued the metal clamps from the coolant line and the inlet to make sure they were tight.
had some caps which i put over the TB inlets/outlets.
done.
this was on a 97 z28
only coolant i lost was whatever was in the inlet hose and the TB which was barely anything. which was next to nothing because car had been sitting.
heres a few notes:
*Do not buy any kit for the tb its a 100% free mod. (might have to buy something to plug up the Tb if you want)
*make sure the car has not been running, do it cold!
*those metal clamps are a bitch!!!!!!!!!have patience and LONG needle nose pliers help out really well. you can push down on the clamps to move them around to a better position to grab them with pliers
*if you reuse the metal clamps make sure you put them on, a way which they are easy to be accessed.
*I had to remove the altenator support which made things easier, I didnt bother putting it back on.
*also had to remove the air inlet elbow
*make sure you use a rag under the inlet/outlets/coolant line...you dont need any spilling on your opti
