Delteq install questions...
A few questions:
Stock manifolds, is the heatshield required? Because I spent around two-three hours trying to figure out why the screw holes wont line up when using the heatshield, even with the heatshield off it was still pretty hard to get them to go (the screws are REALLY short and once you get one side of a coil screwed a bit (just enough to hold) the other side doesnt want to go in, mostly speaking about the rear most coil...
Also, the instructions say to reinstall the studs for the Opti-box, but the factory coil only had one stud and one bolt... I assume they wanted the Opti-box to rest a nuts length away from the head, but with only one stud I dont see that happening... Did you guys just put the washers they included behind the box or...? (Id goto an auto-parts store but over here they dont sell US bolts at all)...
Thanks in advance.
Did you guys do the same (use the metal backing)?
dhdenney, you have headers correct?
