Rocker arm question
Old Aug 22, 2006 | 01:10 PM
TurboZ28's Avatar
Default Rocker arm question
Whats the advantage of roller rockers of stamped ones?
I'm talking about 1.6 rollers vs. 1.6 stamped to be exact.
Old Aug 22, 2006 | 01:21 PM
91camaross's Avatar
less friction
Old Aug 22, 2006 | 03:21 PM
seawolf06's Avatar
They're much stronger as well. You don't want to skimp on parts that are that important and endure that much abuse. Comp Pro Mag all the way.
Old Aug 22, 2006 | 03:23 PM
redhot lt-1's Avatar
i got a question what is the stud size
Old Aug 22, 2006 | 03:30 PM
daniel6718's Avatar
the part that bolts to the head...you want bigger...it willl let it have less side to sied movement and not snap off...also NSA will be safer at high rpm
Old Aug 22, 2006 | 04:39 PM
dhdenney's Avatar
If you use the non-self aligning rockers, be sure to pick up some GMPP guideplates.
Old Aug 22, 2006 | 04:51 PM
daniel6718's Avatar
true^^
Old Aug 23, 2006 | 10:10 AM
TurboZ28's Avatar
Cool thanks.
