Put headlight motor back in my bird..
Old Aug 22, 2006 | 10:58 PM
Gun5's Avatar
Default Put headlight motor back in my bird..
turned it 180 regreased and epoxed it up and either up or down (however much i turn by hand it grinds going up or going down.. what todo?
Old Aug 23, 2006 | 08:06 AM
FlamingChicken's Avatar
if you take the motor back apart and look at the gear hopefully only a a few teeth are stripped on the nylon gear. take it out and rotate it 90 degrees or to where the stripped teeth are all on one side. i believe its the left side, toward the front of the car. that should take care of the grinding. worked for me.
