Car is slow...
Old Aug 23, 2006 | 07:00 PM
jimbob's Avatar
Depends on where your going with the combo...combo...combo and combo...are what's important..forget dyno numbers with stalled autos...For a stall now try Yank SS3600(re-stall if you go bigger combo). PI 3200 (3800) from what I here on a built 350. And, Fuddle line in the 3600 rpm area...All these you can re-stall later to a higher number if needed.
Old Aug 23, 2006 | 07:08 PM
Meen95z's Avatar
Alright, so I get the converter, its gonna help in the 60ft right? Im pulling 1.7's on motor now and if I upgraded its only gonna get me 2 tenths if that over what I have wont it? Right now it seems to leave hard to me, will a bigger converter help midrange and higher power or just low end?
Old Aug 23, 2006 | 07:25 PM
jimbob's Avatar
With a 108 trap speed you'll do maybe 1.65's with good traction (new verter). However your mile an hour will most likely improve because of using that cam with such a tight verter. A cam with the numbers I threw at you "could" give you maybe 2-3 tenths over that cam you have selected....Remember the combo part...You, right now do not make power high enough (rpm) with that cam to be usefull. Go with a smaller cam on a tighter LSA would kick up your 5K-6K power a lot more (where the new verter would like to drop too). Your probably dropping to 4000-4200 rpm on the shifts with what you have now, and that's to narrow of power band with your heads/cam combo, hence no trap speed or good ET.
Old Aug 23, 2006 | 07:30 PM
Meen95z's Avatar
So if I just get alot better heads and bigger converter, the cam will then be useful?
Old Aug 23, 2006 | 07:41 PM
jimbob's Avatar
Lets not make this our private message forum...I will say that better heads, more verter will do wonders...As far as cam goes a "306" is good (manual car cam) but with 112 lsa you can do better for an auto...A lot better in the mid-range. And, that's what it's all about... Talk with the cam grinder guys I mentioned and you will be enlightend....
Old Aug 23, 2006 | 07:43 PM
Meen95z's Avatar
sorry about that, but alright, thanks for the info
