Car is slow...
-fresh 355 ci LT4
-basic ported heads and intake (43.7 hp over stock gmpp lt4's)
-30lb injectors
-52mm tb
-306 cam
-1.6 roller rockers
-forged pistons w/ balanced bottom end
-2800 Vigilante Stall
-3.73 gear
-electric waterpump
-pcm4less tune
-255 fuel pump
-8.5mm msd wires w/ blaster coil
-digital 6 plus msd
-nitrous works wet kit
-pacesetter long tubes coated
-3 in xpipe with spiral flows dumped
-160 stat
-suspension mods
-weld prostars 15x8 and 15x3.5
-granatelli maf
-moroso cai
-trickflow elbow
-Tr6 plugs gaped at .038
-aeromotive adjustable fuel psi regulator
I'd figure it would go faster than 12.60@108. I had a ttop 95z and it went 12.86@107.9 on open ypipe without the electric waterpump, port work, stall, prostars, fuel pump, true duals, 52mm tb, 30lb injectors and aeromotive regulator.. Now I even run a hardtop 95 T/A.
Now the three "C's"....Compression, Cam and Converter......What's the real SCR and DCR...."Cam" is Ok but a custom grind would help torque and horse power....Now, "Converter" is way to small for that cam especially in a 355 inch... I would use a 3600 minimum and really a 4000 stall would be better...(for example, I use a PI 3200, but in my stroker it flashes to 4400 on the launch). On your 355, the verter rating you see are pretty much on unless your making big power.
By the way, I'm assuming you dynoed sense you know max horse power vs. rpm. What was it SAE corrected? and 5600rpm peak is way early on a large cam on a 355 inch engine....something is not right...I usually see peaks of 6300-6500 carrying to 7K rpm with cams that size with good heads and the right compression to run it....
Oh yeah, almost forgot..Just because your heads flow more doesn't mean you'll actually see more power out of them...Trust me on this one....
depending on your altitude,DA etc. you should be able to run 11.60s,you did not mention the type of tire you were on,unless i missed that!if you ran that on radials you are really in for a suprise when you put a sticky tire on!
I will do you one better though.....If your running basically stock compression height/quench and your pistons are 4-8cc dish a cam change to something on the order of Mid 220's Intake/Mid to low 230"s Exhaust on a 10X LSA will do wonders for your time with that small of converter....I bet you would pick up 2-3 mile an hour, and maybe more on your time. What you have is to low of horse power at your shift extension causing it to run low mile an hour/trap speed for the horse power it does make. Talk with either Bret Bauer/Lloyd Elliott or Joe Overton (if he still does cams) and Ai can help too.
Now for the rpm being so low at max hp, that could be a lot of things...My guess heads and cam combo problem...(that's just a guess though and could be wrong)....With just stock Lt4's I would think you would peak atleast over 6k rpm's with that size cam....Remember though LT4's have bigger combustion chamber cc's then LT1's even though they were rated less. I believe they were some where in the 56-58cc's actuall. Your compression might be less then you might believe "These are just some ideas as to the problem, so take with a grain of salt"
Hope this might help you....
Also, a cam to feed those bigger heads would be way different....However, that's some very big heads on a small cubed engine. You'll be running right up there in rpm to make good power out of them 7200 rpm (if your paticular computer will rev that high)....I would suggest a custom cam a way bigger stall with those heads..."It's all about the combo"...and it looks like you may be going to the other extreme of the power range....Personally, I would have those LT4 heads ported (someone who knows heads) have bigger valves installed for them. You would keep the horse power up in the midrange (auto extension) over what your planning. Now if you had a stroker totaly different recommedation might be needed. By the way Ed Wright uses LT4 castings...He's in the 10.1-10.2 area with them...So, when done right they can support big power...
