7000rpm
Is anyone turning there motor between 6-7K in here?I know there are a few,donīt remember who?
GTP PWR and streetwarrior96 any commentīs?
Mine does 6400 with no hesitation.
I ran my 847 to 6700 on the stock bottom, and it pulled hard with no pops, or issues. I was on the stock Ign, no msd or anything.
I have a fresh unit and this starts way before 5500rpm where the stock unit is fine,4k and no power
A cap and rotor doesnt mean didly squat. That is more of a bandaid. Like everyone else said, Its your opti. Instead of changing your cap and rotor just buy a new opti. UA-Plumber: wana bet?50$ itīs the tune or Spring/Valve adjustmennt related not he opti
Iīm trying to datalog but having trouble geting it to work,when i can then well see whatīs wrong
MSD kit is better than the oem unit
I have MSD Coil going to but my oem in and see
I have been in this longer than you so.... STFU
Iīm telling everyone that this is not opti related.Everything that goes wrong is blamed on the opti witch is
Iīm asking for help from people who know what they are saying(your not included
Everyone else,Thanks for the input iīm really thankfull
When i get the computer connected then well see whos wrong and whoīs wright
Using TunerPro 4.13 and DA3.xdf and LT1_92-93.ads
With the old one i had long cranking at startup,studder at low rpmbad mpg ect and know thatīs all gone with the fresh unit so thatīs out of the way
The cam was degreed in, you have the right springs, have you had the covers off since the install to make sure all is adjusted and looks good?
Like Alvin said I would look at the ignition. Also I would get the fuel pressure and for sure get some datalogs when you can. Rule out everything before blaming the tune. I blamed my tune once and felt like a *** when I found out I was having mechanical issues like the tuner said I was.
Remember most of us arent ase pro mechanics. Were just avarage dudes like you who come together to form a big think tank. What you may not of thought of someone else will then in the end we have all learned from it and are able to use the info ourselves when it happens to us or others
Perfect install of the cam ect..
ICM could be bad
I suspected the tune because Alvin sayd that the 93 cant rev near 7k or past,but i thought the pcm could handle 7250rpm MAX so if he thought that he wouldent have edited the bin to that high rpm, spark,fuel ect
Iīm not blaiming Alvin for my problems,he has been very helpfull so he gets my vote for your next tuner but itīs allwayīs a possibility
as far as motors turning 7k in here there are several, i have a 383 on the way that will turn almost 8
Go ahead and rule out the ICM just because since that's pretty easy.
Are you sure Alvin said the 93 cant be reved that high? That's the first Ive heard of it. I even had a post about it and everyone said it could be spun as high as the 94's. Also note that most tachs are off on the dash. If youre spinning to 7k you may only actually be spinning to 6700-6800.
