7000rpm
one more thing check your timing.....sounds like someone fucked up the tune(and yes brian makes mistakes too) with that comp. it'll detonate...with too much timing...(but that won't keep it from going past 5500....)
my guess is OPTIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIII IIIIIIIIIIIIIIIIIIIII!
as I nailed the throttle it pulled good to 4500, missed one time, then pulled to 6k and wouldn't go any higher. (rev limiter is set at 6800) hit second gear and the car started missing about ever 1k to 1500 and started studdering the rev-limiter at 6k again. hit 3rd and the car died.
started the car back, run just fine till I leaned in to in in 5th gear and started stumbling again. I drove the car another 3 miles down the road and progressively got worse with less load (4th gear 1/2 throttle, then 1/4, etc..) then got so bad it died in 1st gear with any load... started back up moved another 100 yards and died, then progressively got harder and harder to start, then would just crank freely.
checked every ignition part (plugs, wires, coil, module, etc.) and noticed that nothing was firing, coil nor injector, plugged in a differeny opti (in my hand) and free spun it and the injectors started squirting, tach started climbing (just like the car was running).
needless to say, a new opti base (with the optical sensor, wheel and backing plate bolted to the front cover) was ordered, installed and drive like a brand new one.
I know everyones on your *** about the scape-goat opti-spark, but if you haven't ACTUALLY changed the optical sensor and wheel part. don't rule it out. if you have, good, that's one less thing you have to buy.
then I'd move on to the spring pressure those springs actually have. could be some sort of valve float issue; back when my car was an auto,it done something similar, would hit 5500, pause, then go to 5800 and shift, then the motor would not physically "pull" past 6200 in gear (valve flat was so bad, the motor didn't have enough power to pull to the shift point) went from ls6 springs to comp 918's and never looked back.
Ok.still have this problem,Got a new opti like everyone sayd was the problem and.....
STILL THE SAME
From 4000-7000rpm tha engine spins very slowly close to 7000rpm,from 4000-7000 the engines pops,very little and silent pops
Anyone care to make a suggestion,Tune is fine.All new parts opti,Coil,Sparkplugs,Wires ect.
Good Luck,
Daren
New plugs, wires, coil - what kind of wires are you running, are they taylor universal over the valve cover wires by chance? if so are you positive that you put the opti spark boots on the wires completely and correct? When I first got those wires I thought I put them together correctly but was wrong, which caused a high rpm breakup. They were a pain in the *** to cut and put together.
What kind of tune do you have, you said you thought that wasnt it but just curious?
My last guess is spring/valvetrain related problem.
I have ported stockers that flowed 290cfm@.600 with a cc306 and 1.6 rrs and I shift at 6800 so you should be able to make power up there easily. I have a dynaspark though
and I'm still on stock intake manifold and tb. i can tell you it should pull to 7,000 no problem. Mine did with K-Motion springs and GM847 cam. as a matter of fact even at 6,900 power never peaked on stock heads. Once I put the LE heads on the Stock short block I picked up 50RWHP and it would peak at 6,800 like it should have.
Gotta get that air in and out to make it all come together.What are you O2s looking like?
This is the log i used LT1_92-93.ads and DA3.xdf
I use Tunerpro Rt 4,14
