is it the new wires...?
Old Aug 29, 2006 | 05:57 PM
z_speedfreak's Avatar
Default is it the new wires...?
has anyone else had any problems with msd wires? i got all new plugs and 8.5wires and half my cylinders are arcing pretty bad i sprayed em down with some wire dryer just now so il see if that helped any once it gets dark here, ther all on there right and tight.. my friend was saying he had a set of msd's before that totally sucked bag.. i wonder if il be able to return them cause of that..? could you guys tell me every lil thing i should check out before i ditch these wires? refund or no refund.
Old Aug 29, 2006 | 06:38 PM
1SLO6's Avatar
put the stock wires back on and see if it goes away...... check to see if u can c the spark off the block or manifolds.
Old Aug 30, 2006 | 07:46 AM
my old wires are in the trash already, they were morroso wires but 1 got burnt on a header so for some reason i just went with the msd to match the box or somin. the wire dryer didnt help any, the spark is still clearly visible at night on the same 2cylinders on each side... no one else has any tips? should i junk these wires too???
Old Aug 30, 2006 | 10:16 AM
Dr. Teeth's Avatar
I had troubles with mine, but the problem was my limp-wristed installations. I found that those that hid behind my BBK headers were difficult to get the right amount of power behind to snap into place, and they weren't seating all the way. NEver checked for arcing but it backfired like all hell. Ended up I had to run my finger down there and feel if it was seated by how much plug was still uncovered. On some of those wires where you're pressing inward while backward and back-handed, you need to be a yoga expert to push hard enough. Anyway, that was my experience. You might also want to try those cloth-material insulators that they sell. I had some that were on the car and they seem to keep the burning down to a minimum, as long as they're routed properly, that is...
Old Sep 2, 2006 | 07:59 AM
yeah ive tripple checked all the connections and ther all on right tight, so im gonna try insulating them with some heavy duty aircraft wire insulation from my buddy's bro which will hopefully do the trick..
