LT1 no2 users.....
Old Aug 31, 2006 | 03:36 AM
96WS6TA's Avatar
Default LT1 no2 users.....
What size/type of shot are you all using??? Want to get a nitrous setup but want to make sure that all of my homework is done first.
Old Aug 31, 2006 | 04:44 AM
Armyman2445's Avatar
150 sometimes 175 Nitrous works system
Old Aug 31, 2006 | 05:43 AM
Louvit's Avatar
120 shot here 13.3 na and 12.6 spraying from 3600 rpm to 5600 only and not launching on it. Just make sure you have all the saftey stuff. mds , window switch, wot switch and the right plugs... and ck you a/f before spraying
Old Aug 31, 2006 | 09:40 AM
streetwarrior96's Avatar
200 shot nitrous Express, dual shark nozzle
Old Aug 31, 2006 | 09:43 AM
TwoFast4Lv's Avatar
175RW bumping to the 200RW Jets Nitro Daves custom DP.
Just fighting to get my small 27in tires to hook
Old Aug 31, 2006 | 10:54 AM
JUICED96Z
Guest
Posts: n/a
You will need a good fuel pump if you plan to spray over a 100. I would get it regardless, if you can find a used fuel pressure regulator (saw one on ehre the other day for $40) then I would get one of those also. NGK TR-6 plugs, good wires, ect ect.
With that you can run a safe 150 shot. Most people that run a 200 shot blow a head gasket or trash a ring in a short matter of time but it might last two runs or a full season. You never know. With an ignition box to pull some timing you could get away with a 175 safe on stock internals.
Nitrous Express here. Got it used super cheap.
Old Aug 31, 2006 | 10:55 AM
Tony Shepherd's Avatar
250 shot two years ago. 300 maybe 400 shot sometime this year.
Old Aug 31, 2006 | 11:17 AM
Greaseymec's Avatar
What a monster! One of these days you'er gonna have to pour all your secrets into my head.lol
Mec
Old Aug 31, 2006 | 03:26 PM
Built LT1's Avatar
TNT F2 LT1 dual nozzle plate system; 150 so far with intentions on going more.
Previously on my LT1 Vette: Nitrous Express 175 shot. Of the two the 150 TNT is more powerful.
I would recommend the brand based on how mch power you want to make. Both kits were/are flawless and reliable for me.
Old Aug 31, 2006 | 03:30 PM
Built LT1's Avatar
Where did you get those pieces to do the intake like that? Will it make more power than the standard K/N style cold air set up? Could you pm me the specifics?
Old Aug 31, 2006 | 07:46 PM
speed_demon24's Avatar
I'm running the HSW wet kit, 125 shot, mallory 685 box, pulling 6 degrees of timing(I'de rather be on the safe side, 475-500rwhp on the stock bottom end is pushing it). I gained 112rwhp, not bad for pulling that much timing. I'm trying to get to the track if it would ever stop raining down here.
Old Sep 1, 2006 | 10:38 AM
pddye's Avatar
I've had the zex 125 shot for 2 years now. It ran 12.2 with a 1.8 60' with a 6 speed car and i've been thru more bottles then i even know what to do with.
Old Sep 1, 2006 | 04:12 PM
harvickgm's Avatar
how many miles do the guys with stock engines have...i have a NX kit... just havent gotten around to putting it on yet.. still need some more things before i install it...
Old Sep 1, 2006 | 09:52 PM
camar0corey's Avatar
I haven't hooked my zex dry kit up yet, but I'm going to be spraying on a 141k+ motor. I still haven't installed the racetronix/walbro fuel pump setup yet I ordered months ago, or wired in the msd retard and window switch.
Old Sep 1, 2006 | 11:58 PM
buffman's Avatar
my friend is spraying a 150 shot on his bolt on 160,000 mile wagon. Of course he has safety mods though.
Local kid just basically has an NX kit with a shark nozzle and went 11.99s with minor bolt ons (gears, stall, shitty local built trans, headers MT ET Drag radials) with a 150 shot and 130k on the engine. BUt it's going about it the dumb way. No window switch, no ignition box, no colder plugs, nothing safety related. Basically an on/ff switch.
Old Sep 2, 2006 | 12:02 AM
harvickgm's Avatar
oh im going to go full safety on it.. but im at the full bolt on 188K mile marker... still runs like a raped ape, but needs a new clutch and rear first, before it goes in...
Old Sep 2, 2006 | 12:03 AM
buffman's Avatar
do a compression test, and if all turns out well prolly would love the spray..
Old Sep 2, 2006 | 12:10 AM
harvickgm's Avatar
yea, i have yet to get around to a compression test... thanks buff
Old Sep 2, 2006 | 12:25 AM
blind527's Avatar
I've sprayed 2 bottles of 150 on my car with a stock fuel pump. Everything is good as gold!
Old Sep 2, 2006 | 10:34 AM
pddye's Avatar
just got back from the track last night in cordova. ran best of 12.0 at 116 so close to the 11 mark its not even funny. w/ 125 zex wet
