gettin hot
Old Aug 31, 2006 | 04:57 AM
96lt1m6's Avatar
Default gettin hot
have you ever seen a stat do this,this is a new one at that!for the last month i had a problem with hi temps,so i changed the stat,had the radiator cleaned,fans are good the low speed fan is quiet compared to the hi speed, is there any way to change that to a hi speed?
well i looked again tonight pulled the stat back out and found this (pictured below)put the new 160*in bled it AGAIN and now its much better i hit the highway,temp was at 165/170 then on the way back i ran it from 65-130 and the temp moved up to 180/185 then slowed to 65 and the temp went back to 165/170 so i will say i finally found the problem
