bad results bad bad!!
Old Sep 3, 2006 | 01:16 AM
  #61
Honda Hunter's Avatar
Good luck with the car. Saw in another thread it wont start now.
Old Sep 3, 2006 | 11:31 AM
  #62
Hark_Z's Avatar
It starts eventually, just dont like the smoking part.
Old Sep 3, 2006 | 11:36 AM
  #63
396D1SS's Avatar
Originally Posted by Stanger88
My 5.0 with a SICK list of mods runs only 14's. Thats why I will never mess up a factory car again. Going stock LS1 next summer
thats funny a buddy of mine has a 91 coupe with a stock 5.0 heads and shortblock with a b cam and long tubes with 3.73's he runs 13.40's
Old Sep 3, 2006 | 11:57 AM
  #64
burnzilla's Avatar
Just because a car has mods, doesnt mean its in good running condition.
There could be all types of problems ranging from electrical to internal, that could make a car lose lots of Hp. Even something as small as a spark plug.
Stanger, I know guys with less mods than you, same car, that run mid 13's.
and Hark, like I already said, you should be in the 12's easy.
Old Sep 3, 2006 | 01:51 PM
  #65
dhdenney's Avatar
Check your water temperature sensor on the front of the water pump. They will cause hard starting and lots of black smoke! Might need to use a scan tool to see if it's working or a voltmeter if you know what to check for.
Old Sep 4, 2006 | 02:08 PM
  #66
SStrokerAce's Avatar
If the injectors are ok why would the gas smell of the fumes badly still? So Bret, you are saying a CC306 would outperform my cam in this situation?
Uh no, the difference would be the lack of TQ that the CC306 gives you.
Change the injectors already!
Old Sep 4, 2006 | 06:50 PM
  #67
s346k's Avatar
injector size has no bearing on how much fuel the engine is getting until it is not getting enough. the injector only feeds as much fuel as it is told, the car running rich is a tuning problem. it seems to me that you need to take this vehicle to a REPUTABLE TUNER with a dyno. so when your car does not perform like it should, said reputable tuner can help pinpoint the problem(s). i think you're aiming high thinking you'll get ~400rwhp out of a mild head/cam lt1 combo, through a stalled automatic to boot. what about a compression test? did you do this work to a worn out motor? what is your shift extension with that stall?
Old Sep 4, 2006 | 07:59 PM
  #68
Hark_Z's Avatar
car's back in the shop.
Old Sep 5, 2006 | 08:22 AM
  #69
Camaro396's Avatar
your kidding right? my 5 liter 89GT runs 13.90s with nothing but headers, h pipe, and flowmasters. and a 4.10 gear but other than that stock with 200k miles.
sorry didnt mean to take thread off topic..
