Speed limiter?
Old Sep 10, 2006 | 03:06 PM
LT1bird's Avatar
Default Speed limiter?
Hey guys whats up? my car apparently has a 110 mph speed limiter. I have heard this was because it had the v6 origionaly so the tires they equiped them with werent rated for the higher speeds. Anyway what do i need to do to get rid of the limiter? thanks in advance!
Old Sep 10, 2006 | 03:12 PM
96capricemgr's Avatar
Aftermarket reprogramming of the pcm is the only fix and that would have been swapped with the engine. I would suggest someone like www.madz28.com
Old Sep 10, 2006 | 06:26 PM
the_merv's Avatar
Veteran: Air Force
How are you running an LT1 with V6 programming?
Old Sep 10, 2006 | 09:56 PM
LT1bird's Avatar
That was what i was told but obviously im wrong. None the less my car shuts down at 110 which is very annoying. Will a hypertech programmer work for getting rid of the speed limiter.
Old Sep 10, 2006 | 10:00 PM
Schweet97Z's Avatar
the hypertech is crap. get a custom mail order program. www.pcmforless.com or www.madz28.com its also cheaper than the hypertech
mumu_624's Avatar
yea friend of mine had one on his 97 camaro and my other friend has a 99 v6 and he doesnt have no speed limiter...
Old Sep 10, 2006 | 10:04 PM
the_merv's Avatar
Veteran: Air Force
I am still trying to figure out how it's that low. Could be the PCM out of a 2.73 rearend car.
Old Sep 10, 2006 | 10:05 PM
mumu_624's Avatar
i heard its the tranny....its a chip or some gear in the tranny...
but im not 100% sure tho.
Old Sep 10, 2006 | 10:08 PM
the_merv's Avatar
Veteran: Air Force
He got robbed..lol Atleast he has a V8.
Mine hit the peg past the 150 mark, and still had more. It was custom tuned though.
Old Sep 10, 2006 | 11:27 PM
LT1bird's Avatar
So my first step would be to go to madz28 and ask him what i need to do?
Old Sep 10, 2006 | 11:57 PM
b00ya4u2's Avatar
my 97 formula was limited at 115, hypertech does take it off but its a useless handheld and id just spend the money and have madz28 tune ur pcm.
Old Sep 11, 2006 | 04:49 AM
MrCadillac's Avatar
the limiter is all in the PCM. PCMforless or madz28 would likely take care of that no problem, and also you will gain power and drivability.
Old Sep 11, 2006 | 04:51 AM
MrCadillac's Avatar
and yes. Hypertech is worthless junk. better off getting an Akm cable, and tunercat, and using a computer to tune it.
Old Sep 11, 2006 | 08:17 AM
the_merv's Avatar
Veteran: Air Force
Yea, the only thing on the Tranny is the Speed Sensor in the back. Nothing to do with limiting the speed.
