The right way to break in an engine,new383
Old Sep 14, 2006 | 01:01 AM
Jays383LT1's Avatar
Default The right way to break in an engine,new383
What is the right way to break in a new engine,"a 383 stroker to be exact". I have heard different stories and dont know who to believe
How many miles do you want to have on the car before you dyno it..
How about a quick break in period, and then straight to be dynoed, I've heard of people doing this and there enigne running fine?or will I regret it?
Any stories with good or bad results..?
Old Sep 14, 2006 | 01:08 AM
streetwarrior96's Avatar
I gave mine 1000 miles and 2 oil changes in that period. I had mine dyno'd at 50 miles. Rev'd like a champ
Old Sep 14, 2006 | 01:32 AM
UnitZ28's Avatar
break it in how you're going to drive it!
Old Sep 14, 2006 | 04:22 AM
Speed Density's Avatar
hashtagBMW
Dont drive it like you stole it, or how ever that goes. Easy on it maybe 25% throttle for 50miles then 50% for 100 and then repeat a few hundred. Then have fun. When i say part throttle i dont mean slow *** daily drive.
Old Sep 14, 2006 | 04:54 AM
MrCadillac's Avatar
actually, you DO wanna drive it like you stole it. To seat the rings properly. After it is warm, first thing: You want to WOT, and take it to say 60% of the redline. Then, engine break from that rpm back to idle. do this several times, then change the oil. The Be easy on it comes from flat tappet cams, that need to harden. If you fail ro seat the rings this way, the walls and rings will be glazed over, and then you will have less power. I'll see if I can find the study, as I know this sounds bad.
Ever wonder why you want a crosshatch and not a silky smooth bore? DING DING DING! to wear the rings, so they seat better.
Old Sep 14, 2006 | 05:15 AM
MrCadillac's Avatar
I knew you wouldn't believe some 19 year old punk, so check it out! http://www.mototuneusa.com/break_in_secrets.htm
Old Sep 14, 2006 | 08:27 AM
Charging TA's Avatar
What Ive been told is to (if you have a manual) to put it in one gear too big and take it from say 2500 to 4500 rpms, then let the engine slow itself down (dont downshift, dont use the brakes, just let it slow itself down... we ran quite a few redlights doing this during rush-hour), do this in 2nd, then repeat in 3rd and 4th... (These were specifically for a Cobra but I know the same thing is used for motorcycles and such, the important part is putting a load on the engine.)
Old Sep 14, 2006 | 09:07 AM
MrCadillac's Avatar
charging ta described it alot better than I did. but thats about it. ya gotta load the rings.
Old Sep 14, 2006 | 09:42 AM
I would just drive mine to a close by town (70 miles every other day... 140 total) I was doing 70-90 MPH not stepping on it. Changed the oil @ 200 miles, 500 miles and 1000 miles.
@50 miles on the clock I took it to get dyno tuned. Tuner tooking it to 6400 with no problems. 14 passes on they dyno
Old Sep 14, 2006 | 10:06 AM
TurboZ28's Avatar
What they said ^^^
Floor it from 2000 to about 4500. Stop. Repeat.
Kinda crazy to feel it get faster and faster everytime you do it.
Also, stop and go traffic is good, highway bad. Cruise around town for a while, as in all day.
Old Sep 14, 2006 | 10:38 AM
95CapriceSS's Avatar
Vary your speed too if your gona have to cruise.
Everything theyve said is what Ive hurd too. I like the idea of drive it like you stole it tho...
Old Sep 14, 2006 | 04:23 PM
z28hustle's Avatar
I heard that the motor can be broken in on the dyno and thats exactly what i intend to do with mine
Old Sep 14, 2006 | 05:19 PM
MUSTANGBRKR02's Avatar
take it to the track on a 100+ day and spray the crap out of it!! this will break it in or is that break it?
do as they say above^^^^^^^^^
