gas? lt1
Old Sep 17, 2006 | 06:22 PM
sdm1234's Avatar
Originally Posted by 00transamnh
but if i can save 5 bucks on a fill up with no effect then whythe hell not
because of problems later on down the road
Old Sep 18, 2006 | 08:54 AM
AVALANCHE&TA's Avatar
According to the owners manual ('94 Trans Am) premium is recommended but mid grade should be OK. I agree with the others though..... with an average of .10 difference from mid grade to premium or even 87 to premium the overall price difference, based on a 16 gal. tank would only be about a $3 savings per a full 16 gal fill up.
Old Sep 18, 2006 | 05:44 PM
96capricemgr's Avatar
Exactly what are these problems you speak of?
I gave an INTELLIGENT reply earlier but most of you seem to have missed it, I guess simple logic escapes you especially backup up with facts like the 10:1 iron head LT1 under more load doing wonderfully with 87 octane. It is all in the tune not the stock engine.
Old Sep 18, 2006 | 05:58 PM
RedRocketZ28's Avatar
I have always heard that on a stock engine the car is fine on 87 or 89. I usually run 89 in mine and can not tell a difference. The only time I run premium is at the track or if I am going to be driving in town a lot. I do mostly highway driving and cant see paying $3 or more per fill up for premium just to cruise at 75 mph.
Old Sep 18, 2006 | 09:59 PM
Speedy's Avatar
Went to the track on Saturday with my stock LT1, zero mods. Tank was full of 87. I ran 14.3 with a .35 RT. It was warm weather, high humidity. Not sure how much better I would have done with 94. Maybe I'll try that next time. But yeah, I run 87 daily with no problems.
Old Sep 18, 2006 | 10:34 PM
sdm1234's Avatar
Originally Posted by 96capricemgr
If a heavy pig of a b-body is OK lugging the motor with 2.56s(wagons) and iron heads at 10:1 the aluminum head engine in a lighter car would be no problem whatsoever to make run on 87 octane.
aluminum head LT1's have higher compression, resulting in higher octane. weight has nothing to do with it... i don't care if u put the LT1 on a go-kart, or a motorcycle. it still needs the proper octane...
wasn't so intelligent afterall, now was it?
Old Sep 18, 2006 | 10:47 PM
Gun5's Avatar
been using 87 the past 2 fillups on my new engine be going premium next round (hell its dirt cheap now) and **** this things gonna rip
Old Sep 19, 2006 | 08:10 AM
Formula96's Avatar
87 is fine unless you advance timeing, make it higher compression, or plan on using nitrous...
just the basics
Old Sep 19, 2006 | 08:12 AM
Formula96's Avatar
Originally Posted by Freaklt1
You're an idiot. The car WILL ping badly under load with 87 octane in the car.
really....
Old Sep 19, 2006 | 10:24 AM
lt197formula's Avatar
The f-body was 10.4 the b-body was 10.0 but with iron heads and everyone knows aluminum allows higher compression.
For a retrofit application you will likely need reprogramming anyway so reprogram it for 87 octane and you will be fine.
I thought they f-bodies were 10.4 except the 97's which they bumped up to 10.5?
Old Sep 19, 2006 | 05:28 PM
As I already covered it is widely accepted that aluminum allows more compression than iron without tuning issues and the number usually placed on that is one full point. The iron head motors are just .4 shy.
Weight has to do with LOAD, LOAD has EVERYTHING to do with timing and detonation resistance don't believe me go and take either your part throttle or WOT timing and use that column across the whole MAP range and let us know how that works for you.
Old Sep 19, 2006 | 07:29 PM
  #32
sdm1234's Avatar
with high compression heads + pistons, higher octane is not just an option for whatever kind of driving you do. i have a Gen I LT1 pushing out 600+ HP with the compression running so high, it requires avaiation fuel (108+ octane). just because i had it in my '23 Bucket T (2500 lbs) and never took it over 65 didn't mean i could put 87 octane in it. your logic sounds correct in your head, but the calculations just don't add up on paper.
sure... the lower octane may DETONATE and the PCM may allow timing adjustments, but as for combustion efficiency, you'll never see proper results...
please, don't challenge me on this subject. i know what i'm talking about.
Old Sep 19, 2006 | 07:47 PM
  #33
nomoneyz's Avatar
after reading this i went and filled up my tank with premium while its cheap i normally ran 87. well i didnt notice a power difference but i did notice a noise difference. sounded smoother at wot it could be in my head though btw i have no knowledge on how octane ratings work.
Old Sep 19, 2006 | 07:54 PM
  #34
Camaro Bird 1987's Avatar
The lower octane will be okay to use. The knock senser will detect the ping and pull timing, you just won't run as fast as you would with higher octane.
Old Sep 19, 2006 | 08:03 PM
  #35
Thank you for proving the invalidity of your comments on this.
We are talking on a stock LT1 which is worlds apart from what you are talking about.
When I had just a mild cam I ran 87 octane yet with appropriate programming, never a ping audible and rarely when I was datalogging. With the AI setup though we pushed compression on a stock shortblock to 11.5:1 now she gets super, but going by your logic if the 10.4:1 stock motor needs 91 then I would need more than that wouldn't I??????
You may know carbed crap but I have a pretty good handle on the LT1 and it's injection and sofar you are not showing much knowledge there.
Again I am not saying everyone with with a stock motor and tuning should run 87 I am saying with proper tuning it WILL work perfectly.
Old Sep 19, 2006 | 09:42 PM
  #36
sdm1234's Avatar
cam and tune is considered stock? contradictory, yes?
stock gen II LT1... i'd say high octane; load or no load. period. please don't continue this discussion.
Old Sep 19, 2006 | 10:11 PM
  #37
I was saying even on my cammed motor, stock it is fine as I have said over and over the IRON head motor at 10:1 was rated for 87 from the factory. It is widely accepted that aluminum allows up to one point more compression without detonation issues so where is the flaw in my logic. Seems to me you are the one being blindly rigid without an ounce of THOUGHT here.
I REALLY get sick of you ignorant f-body kids(reguardless of age) incapable of thought and will not back down because in doing so I just allow you to spread your ignorance.
DETAILS, EXACTLY what part of my argument as far as the iron head motor being factory speced for 87 so the aluminum one needs nothing but a tune to run it is flawed??? Not your different application and no facts answers sofar answer this directly, if you can't do that you prove my assertion of your ignorance.
Old Sep 20, 2006 | 01:30 AM
  #38
urbanhunter44's Avatar
I know both my LT1s and friends LT1s all run like **** on 87/89. Gas mileage goes down, performance drops, feel shaky, idle bad, take longer to start and ping like ************. They need 91, even says so in the owners manual and the fuel door.
Old Sep 20, 2006 | 09:26 AM
  #39
They don't need 91. My car runs the same on 89 as it does on 91. Gas mileage is roughly the same as well. If my car did all the things you mentioned on 89 then yeah I wouldnt run it. But for some of you to say they all NEED 91 is false. I think 96capricemgr pretty much covered everything. Some of you need to listen to him.
Old Sep 20, 2006 | 10:28 AM
  #40
TurboZ28's Avatar
Mine ran pretty horrible on 87. It seems some people notice a problem and some don't. Fill up with 87 and if you don't notice a change in performance then go for it.
