gas? lt1
I'm considering converting mine to run on 100% E85.
You are an IDIOT too.
I am talking about the 94-96 b-body LT1 how is that an older LT1 same exact bottomend as the LT1 f-body, and you show me ONE SINGLE SCRAP of evidence to support this 96-7 higher compression stupidity some of you are pushing. I already repeatedly covered why the .4 extra compression of the aluminum heads motors should not make it require premium. GM tuned it that way and you can undo that with simple reprogramming.
How about we go at this another way if some of you are so frigging increadibly intelligent how is it that a 10.4:1 motor requires 91 octane as you say, but my 11.5:1 motor gets by on 93 octane wonderfully.
You are claiming that despite the iron heads 10:1 spec with 87 octane the .4 increase tthe aluminum head motor got requires 91 that is a ratio of increase of one tenth of a point compression to one point octane requirement, by your logic I need like 102 octane in my current setup how is it I am able to get trhe results I am on 93 then??????
To those of you on the fence here notice every DIRECT question asking them to refute my stand fact for fact is ignored, that is very telling, those arguing with me are wrong and can not support their argument.
LOL someone who doesnt read well
Mr.Camaro you can premium in that motor as long as you have a good tune from what I've read.
Some things to think about running pump gas on higher compression
-160 stat
-fans on early
-healthy oil pressure to protect bearings
-propper quench aka very little
-smooth chambers and or coatings
-electric water pump
-more rear gear equals less load
-make 100% sure your getting air from outside the engine bay
-get a good in person dyno / STREET tune
Seriously I have tuned 13.5:1 LT1s with stick cars with little 3.23 or less rear gears.
11.5:1 Cali 91 pump gas LT-1s, is an everyday event for me here at Race-Prep.
https://ls1tech.com/forums/lt1-lt4-modifications/170957-basic-lt1-specifications.html
i'm not going to search for information you should already know. do your own homework. also, watch your language and don't harass any of the other members...
sdm1234, AGAIN I challenge you to refute my claims point for point.
You act like we are the ones in the wrong, you repeatedly tried to spread your ignorance and I would not tolerate it, I did this forum a favor.
Far as your claim of the 10.5 this forum alone is not proof I can find you as much bad info posted by folks like yourself as I can find good posted by the likes of GIZMO, Ed, Ellis, etc.
LT1MAN I dare you to go back and read my posts and try to refute them point for point too, you are yet another idiot and the only way the forum as a whole can grow is if idiots are called such and their input taken with a grain of salt.
we call em winter beaters up here
somebody lock this thread please so 96capricemgr discontinues the harassment.
