'Hissing' sound from new fuel pump, normal?
Old 09-18-2006 | 06:41 PM
azmarkus's Avatar
Default 'Hissing' sound from new fuel pump, normal?
Had a new fuel pump installed in the Z (94 M6) and when the car is running I get what sounds like an audible hissing noise inside the car (coming from the back of the car). I was told this is normal? The replacement pump is an AC Delco unit.
Old 09-18-2006 | 06:52 PM
dhdenney's Avatar
I would probably expect that noise from an aftermarket pump but I'm not sure about a factory pump. I would think a factory pump should be very quiet. Even my 255 lph GMS pump is inaudible.
Old 09-18-2006 | 07:16 PM
Speed Density's Avatar
hashtagBMW
My factory pump is loud at start, usualy thats a good sign its working properly.
Tony.
Old 09-18-2006 | 07:18 PM
95formulalt1's Avatar
i have a sound too
Old 09-18-2006 | 08:43 PM
azmarkus's Avatar
Thanks everybody...
Old 09-19-2006 | 10:54 PM
LS1eater20's Avatar
it a GM ... 95% of GM have really load fuel pumps ... so you only have a problem if you dont hear that sound ... means its not working
Quick Reply: 'Hissing' sound from new fuel pump, normal?
