anyone running a le2 383 stroker setup?
Old Sep 19, 2006 | 02:22 PM
gpss02's Avatar
Default anyone running a le2 383 stroker setup?
i just picked up a 383 stroker block,crank and pistons last night..and i'm planning on building up a le2 383 setup...what are you guys putting down with this setup? anywhere near 400?
Old Sep 19, 2006 | 03:40 PM
streetwarrior96's Avatar
you should get there with no problems
Old Sep 19, 2006 | 08:02 PM
sheikss's Avatar
I'm in the process of finishing mine now. I've seen 440+ at the wheels with a ele. water pump, 6 spd, and stock 10 bolt.
Old Sep 19, 2006 | 08:13 PM
yotaman96's Avatar
Mine's in the works as well.
Old Sep 19, 2006 | 09:16 PM
CNC Stew's Avatar
I'm on the north side of 400rw through a TH400 and using a smallish cam.
The LE3 LT4 heads really work well.
Dean
