Engine Info
Old Sep 21, 2006 | 12:59 PM
the_merv's Avatar
Default Engine Info
Anyone have any info on these guys..
http://www.golenengineservice.com/ht...rt_blocks.html
Old Sep 22, 2006 | 08:51 AM
Chris 96 WS6's Avatar
No first hand info, but I've heard from several folks they do good work. The prices seem reasonable.
Old Sep 22, 2006 | 09:18 AM
borninatransam's Avatar
they seem pretty reasonable and ive heard nothing but good things from other board members. do a search and see what you can come up with. i dont know if it will return as many results for lt1s as it will ls1s. but if i were you i would get the assembled block and bottom end but would leave off the heads. with one of their 383 short blocks w/o forged internals you'd be better off buying a set of port pros, afrs, or llyods. while they do have some porting you can go with some better options(i.e. 2.02"/1.60", 200cc runners, and according combustion chambers for what youre going for.) basically what im trying to say is you can make more power for less or equal to the price of an assembled motor.
Old Sep 22, 2006 | 10:03 AM
the_merv's Avatar
That's what I was planning if I can't fix mine that's in it already. I was going to send my Heads off, and have them ported. Probably have them done by Port Pros. The Cam I was looking at for that Motor was Comp Cam 230/236, 576/570, 113 LSA. It should be a decent combo.
