any one using the Canton oil pan
However, the latest replacement pan I received (with the lastest changes as of then)from them was in early July. You are saying they made another change since that time?
I'm not sure of the date of the changes, but yes they did change the outward position of the dipstick "V", which solved the dipstick problem. It is still available under the 15-244T part number. The new version is part number 15-242T, and has the updates in my previous post. The nice thing about the new version is that although more shallow in the front, it still clears 3.875" stroke without any modifications.
Additional note: According to Canton, NO additional changes/corrections are planned for the 15-244T.
<small>[ December 10, 2002, 08:43 PM: Message edited by: arnie ]</small>
I had the sensor moves around the 45* corner and it fits just fine now.
No problems with the steering rack as far as I can tell.
Dipstick seems to clear the pan ok, but it hits the 4bolt main.
I'll probably cut the tube short and use a cap when the motor is running.
I tried bending it a little, but I can't get enough of a bend into it and still insert
it with headers installed. Worked great with the block on the stand though
Many regrets at purchasing this pan, I would certainly look at a different solution if I had it to do over again.
