Turbo system
Old Sep 21, 2006 | 10:45 PM
onebadblackz's Avatar
Default Turbo system
what all is needed for a single turbo system.... headers ect
Old Sep 21, 2006 | 11:15 PM
whyte95ZRida's Avatar
Turbo, corresponding turbo flange, wastegate, BOV, high flow injectors, higher flow fuel pump or add in a inline fuel pump, intercooler, tubing, good clamps and high temp rubber hoses, fab skills, welder, and a dyno tune. Should be about it. Unless you want to put in a boost controller, boost pressure sensor, exhaust temp sensor, and all corresponding gauges.
Fully forged internals doesn't hurt.....if you want big boost you will have to. Stock i wouldn't push over 10 psi. IMO.
Old Sep 21, 2006 | 11:26 PM
sdm1234's Avatar
i hear 10 psi is still high for a stock motor. don't most people run 5-8 psi with stock?
Old Sep 21, 2006 | 11:27 PM
See i'd run 10 because i want to build it for more boost
Old Sep 21, 2006 | 11:35 PM
I have forged internals
Old Sep 21, 2006 | 11:48 PM
sdm1234's Avatar
yes, good point lol. break it, and rebuild it...
Old Sep 22, 2006 | 01:01 AM
harvickgm's Avatar
then you can build it for 20.... oh yea....
Old Sep 22, 2006 | 01:02 AM
Then that should be all you in what i listed. Just gotta make sure you can make it all seals right when you do it and not have any wires/hose that the turbo could get hot enough to melt near the turbo.
Edit: Don't forget your oil lines. I forgot to meantion that.
