where to get Optispark bearing?
Old Dec 30, 2002 | 02:11 PM
Ellis Wun's Avatar
Default where to get Optispark bearing?
Does anyone know of a source for a replacement bearing for an Opti-spark? The original bearing is made by NTN and shows as #SX03A13LUACS25. GM apparently does not sell this individual bearing and the local bearing suppliers do not have this one. Any help appreciated....
Old Dec 30, 2002 | 08:50 PM
TwoFast4Lv's Avatar
Default Re: Optispark bearing - - source??
Would LOVE to know if you find any.
BTW is that a 92-94 or 95-97?
Old Dec 31, 2002 | 08:56 AM
Ellis Wun's Avatar
Part number indicated is for a vented Opti, 95-97. If nobody responds here, I will try contacting NTN directly.
Old May 7, 2012 | 04:09 PM
stevo9389's Avatar
10 year old bump
anybody ever find out if/where these can be sourced?
Old May 7, 2012 | 04:41 PM
BIGCAT7274's Avatar
Originally Posted by stevo9389
10 year old bump
call a bearing company. i deal with miller bearing here in orlando. they seam to be able to get just about anything. but keep in mind it maybe a proprietary part for gm. i have ran into this before at work.
Old May 7, 2012 | 05:27 PM
stevo9389's Avatar
if i could press mine out and get the measurements i would have already placed a call. kinda hopin someone already did the work and would be forthcomming.
Old May 7, 2012 | 07:24 PM
RGSS's Avatar
I disassembled an opti once thinking of replacing the bearing.
One of the problems I ran into is that the shaft and the rotor hub are assembled with an interference fit and there is no way to reassemble them in the exact same angular position, unless you have a gig set up for this purpose.
I might be wrong though. This was several years ago.
I then decided to just get a new one.
Old May 7, 2012 | 09:21 PM
wrd1972's Avatar
10 year old bump
I have disassembled my opti down to the bearing. You MUST scribe some indexing marks for the two press fit pieces in order to get them "clocked" right or the opti wont work. When I first reassembled my first one, I did not do this and it took a while to figure out where I fukd up LOL.
You can also repack the bering with grease by removing the seal assuming its not worn.
