Lt1 intake porting
Old Jan 4, 2003 | 10:07 PM
LPE Z Convt's Avatar
Default Lt1 intake porting
Do any of you experienced racers know where i can get my intake cut and ported ? LPE ported it but i was told that to get the most out of it the intake needs to be cut ported and rewelded. Any info would be great ... Reason i am asking is because i plan on upgrading to a bigger cam, any recomindations?
Old Jan 5, 2003 | 09:23 AM
I8AFORD's Avatar
Default Re: Lt1 intake porting
talk to Craig at GTP
or Brian Tooley at TEA
Old Jan 5, 2003 | 01:17 PM
PNYKILR's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by LPE Z Convt:
<strong> Do any of you experienced racers know where i can get my intake cut and ported ? LPE ported it but i was told that to get the most out of it the intake needs to be cut ported and rewelded. Any info would be great ... Reason i am asking is because i plan on upgrading to a bigger cam, any recomindations? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not really worth the cost and time cutting the intake open. GTP just did my setup and basic porting on the intake was all that was needed. Take a good look at your intake. Really can't take that much out of it, other than porting the runners, and cutting the front open more to a 58mm TB. Not worth it.
Just my 2 cents worth.
Old Jan 5, 2003 | 10:55 PM
Gangly's Avatar
LT1 intakes are very good to begin with, cant really port them and get a lot of HP because they already flow great. like the above statement, the only realy porting that might be benificial is to open up the throtle body opening in the intake to 58mm.
Old Jan 6, 2003 | 08:42 PM
TwoFast4Lv's Avatar
The BIGGEST improvement is by welding the roof over every port and then raising ti till the port is symtrical...
Then again this only really helps on extreme cubic inch /RPM motors <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
