cams
Old Jan 6, 2003 | 10:07 PM
LPE Z Convt's Avatar
Default cams
What is the best cam to go with to generate the best power for a heads cam car on and offf the bottle? I dont really care about gas mileage I just want raw power.. Do you have to choose between all motor cam or a nitrous cam? Can you have both? Stock bottom end, top end kit done by LPE. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Jan 6, 2003 | 11:17 PM
Gangly's Avatar
Default Re: cams
Comp Cams 306 is a good cam for all motor and spray uses.
Old Jan 7, 2003 | 01:47 PM
yellowpontiac's Avatar
Default Re: cams
how would a comp cams 305 cam 220/230@ .50 .544/.544 114lsa be for a car with a few bolt-ons (headers, programmer, 52mm,). would it be to agressive and would you have to reprogram the computer? or a more important question...would it give me mid to top end? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jan 7, 2003 | 07:57 PM
TwoFast4Lv's Avatar
Default Re: cams
GM #847 is a good choice also. they are only $204 and Billet <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jan 7, 2003 | 11:37 PM
Gangly's Avatar
Default Re: cams
the 305 cam is .510/.510 lift unless you have 1.6 RR's. but yes, it would give you good mid to top end power, and its halfway decent for spray if you ever decide to spray the car.
Old Jan 10, 2003 | 10:36 AM
Ram Air LT1's Avatar
Default Re: cams
I have the comp 306 in my car with lt-4 heads and intake i drive about 120 miles a day average around 20mpg and the car has been a best of 11.82@119.97 on the motor and on drag radials. I havent tried the n2o yet but i here alot of people say it works well with the cam hope this helps
Old Jan 10, 2003 | 11:54 AM
solid95z's Avatar
Default Re: cams
If you are lookin' for an "off-the-shelf" cam, The Comp Cams 306 is the way to go. But the BEST way to go in anycase is a custom ground cam. It will match to your heads and will give you optimal performance for your application. But they are more expensive.
If you look around you can find a used CC306 for about $175 used (if you decide to go that way).
Scott
Old Jan 10, 2003 | 05:14 PM
Default Re: cams
would you absolutely have to reprogram it, if you install the 305 or the 306. <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Old Jan 14, 2003 | 02:45 AM
Gangly's Avatar
Default Re: cams
if your an auto, anything with a 112 LSA will almost definately need computer reprogramming. if you are a 6 spd, you can idle with just about darn near any cam. now, to get the best from a cam, you will most assuredly need to have it tuned. no cam can be thrown into the motor and be expected to put out record numbers without a little tuning here and there. back to the questions, can you run them without programming....on a 6 spd yes, you can run both the cams without tuning and have good performance, on a auto, the 306 cam will be darn near impossible to use as a daily driver without tuning and the 305 cam could possibly go without tuning, but not likely, and both would run like poopoo until tuned on the auto.
