stall converter and OBD1
Old Jan 13, 2003 | 09:08 PM
vince3's Avatar
Default stall converter and OBD1
ive read somewhere that te cpu has problems
with converters larger than 3200 stall.
is this true??
Old Jan 13, 2003 | 09:38 PM
TwoFast4Lv's Avatar
Default Re: stall converter and OBD1
Depending on HOW hard you launch the car P.I. 2,800s are mostly the safest best <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jan 14, 2003 | 12:27 AM
vince3's Avatar
so what would happen with a bigger stall???
Old Jan 14, 2003 | 02:36 AM
Gangly's Avatar
the computer really only has a problem with the shifting. for some reason, anything 2800 and above and the car will bounce off the revlimiter before shifting or wont shift at all until you let off for a second. just reprogram the computer, adjust shift points, or raise the revlimiter a little bit. how you been man, aint seen or heard from you in a while. finally got the car back this past saturday night. still breaking it in after the heads, cam, intake, tb, rings, bearings, arp rod bolts etc was installed. will have it out this coming weekend if you want to meet up or is your car still on bricks like mine was for the past 2.5 months. laters
Old Jan 14, 2003 | 10:31 AM
Shon Herron's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TAraysr:
<strong> the computer really only has a problem with the shifting. for some reason, anything 2800 and above and the car will bounce off the revlimiter before shifting or wont shift at all until you let off for a second. just reprogram the computer, adjust shift points, or raise the revlimiter a little bit. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The processing speed of the OBDI is too slow to keep up, it freaks out and goes to Limp Home Mode. I ran a ST3500 with no problems unless I brake stalled it, then it would: 1st gear, bang limiter, then 3rd gear.
Messing with all the LT1edit stuff did not change that. I had the limiter set at 6700 and hit is several times, along with all the other stuff that could be changed. Code can be changed and PCMforLess has had a good run on fixing it.
Some cars have the problem and others dont. You will know it when you do.
Good luck!
Old Jan 14, 2003 | 11:39 AM
Gangly's Avatar
sorry, even though the title says it, i for some reason was thinkin vince's car was a 96 like mine, a 1996 <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> . thanx for the correction
Old Jan 14, 2003 | 08:45 PM
TwoFast4Lv's Avatar
I may be releasing a solid fix for this very soon. it will be dirt heap but Programming will be needed <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I talked to one of Brians testers the other day and he was having the problem again even after the fix...
