Who does the best LT1 head work????
Old Sep 25, 2006 | 01:06 PM
Fastbird93's Avatar
Another good one is the guy who does Joe O's heads....E.B. Porting I believe.
Port size plays a ton in a motors ability to produce power, both on small and larger cube motors. Go too big on a small motor, you lose port velocity and your numbers will suffer. Go too small on a bigger motor and you'll choke off it's ability to breathe, and your numbers will suffer.
Old Sep 25, 2006 | 06:01 PM
96capricemgr's Avatar
Originally Posted by IllusionalTA
I have 245cc runner's going on my 396... Do you honestly think 195cc can feed a larger cube motor such as a 383/396 as well as a 220cc etc? it all basically comes down to what are you going to do w/ your car.. and of course your budget.. That usually dictate's more than your goals...
http://web.camaross.com/forums/showthread.php?t=450012
Ever hear the saying "the proof is in the pudding"? They are now offering a 200cc package as well. That motor is about 1.7hp per cube at the crank and that is with heads "too small" and intake that according to most here are not up to the task of a strong street engine, that is still MAF even .
Far as a answer to your question I think you are better off with a good 195cc port than you are a poor 220cc port.
Old Sep 25, 2006 | 07:35 PM
IllusionalTA's Avatar
I didn't say it couldnt'.. Just said "as good as".. IOW.. Saying the same guy port's both set's.. your telling me a better more powerful combo cannot be had w/ a 220cc port? apparantly the 195 is doing a great job.. but who's to say a 220 wouldn't be better? I'm not arguing the fact the 195 make's great power, or whatever.. But just trying to broaden this discussion... Rick's car is no cookie cutter setup either.. i'm sure.. Great combo's usually work well together..
Old Sep 25, 2006 | 07:53 PM
Rick's car is not as exotic as most want to believe. Heck there are folks claiming mine is a racer because far as heads/cam b-bodies go it REALLY stands out performance wise and I have not run it in any really good weather yet. There are just 4 heads/cam b-bodies faster than I, all run open exhaust drag tires and rims all round etc whereas my car I drive all week slap on the slicks and run. The guy who holds that record has even told me he thinks I should have no problem beating his record and his was lightened to the point of even removing the catback to save weight.
I really need to get some locals to vouch for how NOT a racer my car is, not that it is anywhere near the level you are talking about but I just get tired of everytime a combo works people want to believe it is all in the car, often it is in the car more than the motor but we still need to give credit where it is due and recognize a lot of shops are doing amazing things with stock castings these days, things just a couple years ago were "impossible".
Old Sep 25, 2006 | 09:26 PM
1fastwagon's Avatar
Originally Posted by scrmnws6
I am very happy with my heads from Lloyd Elliot.
ditto!!!!!!!!!!!
Old Sep 25, 2006 | 11:21 PM
onebadblackz's Avatar
how much is it for a full h/c including RR, pushrods.... ect or does it come with it from AI.....
also a buddy of mine with a 180cc h/c package from AI with stock exhaust manifold is claiming he ran high 11's
what do yall think???
Old Sep 26, 2006 | 07:00 AM
I never said it was exotic.. It's got LTx castings for christ's sake.. It's just a well thought out combo.. And work's well... My bolt on LT1 went 12.80's@3933lbs raceweight.. that's def. not the norm.. It don't matter to me how fast Bob,lou, harry and what not go.. Folk's take things out of context.. Most have car's that run great.. rick's is a fine example. But if it was sooo easy and "just" a AI Heads/cam package.. Then i'm expecting to see at least a handful of 10.80 A.I headed LT1 casting car's.. Or even 2 500rwhp M6 one's..
I just wish the LTx castings were the way to go for my setup.. If someone honestly told me a LTx casting will get the job done and meet my goal's, probably would hvae saved the 1800 that i spent on bare casting's and umteen other $$$ porting, and what not.. All's i'm trying to get at.. every car requires' a diff combo.. And the same head that work's great on your 350 might not get the job done on a 383 or larger cube motor... It might make Ok power.. But there is def. power left on the table.. Even in the 350c.i sector...
Old Sep 26, 2006 | 04:10 PM
Speed Density's Avatar
hashtagBMW
Talk to Harold at Port Pros.
Tony.
Old Sep 26, 2006 | 05:30 PM
ABA383's Avatar
I was going to chime in and recommend E.B. Porting...He did a great job on my LT1 castings with 2.00/1.56s...I just went 119.5 mph in bad air with a weenie Joe O. spec'd cam last Friday...His stuff flat out works at the track...
My car doesn't dyno well, but it puts up the numbers where it really counts...
--Alan
Old Sep 26, 2006 | 05:59 PM
CNC Stew's Avatar
[QUOTE=ABA383]I just went 119.5 mph[QUOTE]
Nice speed Alan.
Dean
Old Sep 26, 2006 | 06:21 PM
ABA383's Avatar
[QUOTE=CNC Stew][QUOTE=ABA383]I just went 119.5 mph
Nice speed Alan.
Dean
Thanks Dean...I think theres a 120 in it in good air, and I'm doing some suspension tweaking to better my 1.59 60'..I want to justify the fight I just won with my wife to get a roll bar...c'mon 11.49s...hahaha...
--Alan
Old Sep 26, 2006 | 06:43 PM
  #32
METAL MANIAC's Avatar
Guys,
Thanks for all the great input. I guess the biggest question I am asking is how big of a diffrence can a cnc port job make...can a 195cc runner cnc port job make the flow numbers a non cnc 220cc port job make. fbodymotorsports claim these heads will make more power than most lt1 heads with port sizes up to 220cc. Has anybody ever bought heads from these guys?? As I said I will also be running a solid roller camshaft probably in the 240-244 degree at .50 duration...not huge but not small...this will be a street rod...not a drag strip caror rather should I say it might see the drag strip, but it will mostly be a street car...thanks MM
Old Sep 26, 2006 | 06:56 PM
  #33
ABA383's Avatar
Find out who the fast/satisfied people who run similar set ups are and what they are running...Pick their brains and find out who they are using...In my case I followed Joe Overton for a while and used his sources...
--Alan
