CHECK THIS ONE out. what do you think?
the problem is. i went through a coil. 3 sets of plugs )tryin to get it right) burned some wires and cut 1 on the a/c pully. new opti . msd cap and rotor.
IN ORDER
1st. my rotor exploded whitch is commom for the stock lt1 rotor.
2nd. then went out my msd coil.
then a set of plugs.(cuz my wires were fuct( my fault)
3rd. opti spark.
and still misses BUT
off of my battery theres a RED wire going up onto the wheel well connecting it to a RED little box( with a cap) out of that box come some( fusable link wires /black)
well that box got melted and the RED wire off of my battert is extremely HOT. so thats my prob at the moment. what could make that wire get sooo damn hot????
please help. i miss drivin my baby.
some mods. on the motor are just, bbk 58 t.b. bbk shorty headers. no cats to a borla exh( for an LS1 3.5 inch) msg cap rotor & coil .the baby crane cam. lots of other mods to car just havent done the motor RIGHT quite yet. please help...
It'd probably help to find out what that thing is a remove it asap so your battery doesn't die. I'm not exactly sure how related to youre other electrical failures it is (failing coil and missfires), but I'm willing to bet its pretty close.
First, remove the block (slide it towards the driver side and lift up) and look underneath it. Make sure the metal contacts inside are not touching the chassis. Then physically inspect every single wire running off the block, searching for any exposed wires, melted insulation, etc.
You should really hook an ammeter to the battery and check the current draw, then start disconnecting the fusible links one at a time and see which one has the highest current (least resistance).
ANYONE know why the dash would smoke directly in the center of a 94 Z28? its in the dash. not on my car. what is in there that would smoke? and thing like the CCM or any box? i know the harness runs back there.
I would check each wire for continuity, resistance, and voltage. All three are available on a multimeter, which are extremely inexpensive. This is much easier than checking for current draw, and would give you a much broader understanding of what is happening, IMHO.
