losing power
Old Sep 25, 2006 | 11:13 PM
teamguru69's Avatar
Default losing power
I was leaving the bank this afternoon and i did a lil sliding ..but i think that i seriously screwd up my car ...no whenever i drive in lower rpms(1k-3K) it feels real sluggish like i am losing alot of power...it idles fine and it revs fine, so i think that i might of messed up my rearend..what do you guys think happend? mods in sig..thanks
Old Sep 25, 2006 | 11:57 PM
onebadblackz's Avatar
i don't know if this might help but when mine felt that way i changed the plugs and wires and it got its pep back...
good luck
Old Sep 26, 2006 | 01:08 AM
teamguru69's Avatar
i changed them not to long ago..about 2 months, but ill check them..
Old Sep 26, 2006 | 07:50 AM
95FbFormula's Avatar
I dont know if this would help but last time i went sliding i broke the posi it will still drive and everything but when i would power brake it would only spin the pass side wheel. You can easily check by having the rear end up on stands or jacked up and have someone start the car and see if both wheels spin if not time for a new carrier. That could be your problem.
Old Sep 27, 2006 | 01:35 AM
teamguru69's Avatar
yeah thats what i was thinking it might be..it feels like i am a gear to high..like ill be going 40 and ill be in 4th but its like it rides like im in 5th..
Old Sep 27, 2006 | 07:37 PM
MrCadillac's Avatar
how does the posi have any effect of the power level you feel? and if the posi died, I don't think it's gonna make t feel slugish. BUT, if the geometry changed, or the parts start binding, I can see how it could effect it.
Old Sep 27, 2006 | 09:02 PM
99S351's Avatar
Bad Trader (Louis H)
Sounds to me like your bogging at lower RPM!
Old Sep 27, 2006 | 09:26 PM
teamguru69's Avatar
when i am sitting at a light i rev and it goes up through the RPMs fine
Old Sep 28, 2006 | 02:34 AM
MrCadillac's Avatar
One of my cars would do that as well, rev fine at a light, and light throttle/down hill. But once a load was put on it, it bogged... well, turned out to be a constant miss fire... it was a cracked plug. I drove that car for 2 months like that... DAMN I was dumb...
Old Sep 28, 2006 | 03:18 AM
teamguru69's Avatar
ill check them today..thanks
Old Sep 28, 2006 | 05:11 AM
MrCadillac's Avatar
I found(almost on accident), that a good way to find this out, is pull the plug out with greasy hands. the grease gets in the hair line crack, and you can see it very well.
I was gonna pull all the plugs, then go to the store and replace them. well, very first plug I pull, I see that hair crack in the ceramic. replace that one, missfire was gone. They were around a year old... after I parked the car for 6 months...
