oil pan
Old Mar 31, 2003 | 07:51 PM
Ram Air LT1's Avatar
Default oil pan
Does anyone know if you can run a regular small block oil pan on an lt1? I am doing a stroker when I priced oil pans with the low oil sensor bung I decided the low oil sensor isnt that important to me. If clearance is the issue I plan on going to the tubular k-frame. thanks Josh
Old Apr 5, 2003 | 07:42 PM
John35thSS's Avatar
Default Re: oil pan
I think the only difference in chev pans is one piece or two piece rear main seal. Bought a canton before I spoke to Wade at A.R.E. and I regret not waiting for his advice. Give them a call to find out what works before you waste any money.
Old Apr 7, 2003 | 10:22 PM
Gangly's Avatar
Default Re: oil pan
why not just cut a hole in the oil pan and weld a fitting for the Low Oil Sensor...would be VERY easy to do?
