underdrive pulley question
Old 09-30-2006 | 03:38 PM
brynnda's Avatar
and where do we buy that? i wanted hypertec but i cant find where to buy one.
Old 09-30-2006 | 07:27 PM
buffman's Avatar
Originally Posted by MrCadillac
I don't see how the underdrive pulley would kill the battery. If the under drive is not charging enough, go with the OD alt pulley. if you already have it, I'm very confused... it may drain the battery, but Kill it, so it won't hold a charge?
Corey,
Spartus was having this problem back when he ran underdrive crank pulley. Even with an overdrive alt pulley he had barely enough power to keep the car running at idle at times.
Old 09-30-2006 | 09:38 PM
the_merv's Avatar
You have to be draining some juice to have that. I have a 34% reduction Crank Puley, and the stock Alternator Pulley. I have never had any problems with mine..I checked the voltage with High Beams on, and Doors open so all the lights were on when it was at idle to see what it was, and it was barely below midway. I have the 140A high-output, so maybe he might need a bigger Alternator.
Old 09-30-2006 | 09:48 PM
camar0corey's Avatar
I'm using a optima red top, the smaller one, and I only notice a slight drain if I have the hibeams on and the fans on high. If I just flip the fans on it dips for a second and then it comes back up.
Someone makes a replacement/underdrive balancer? I had looked and looked when I ordered my underdrive pullies and I couldn't find one.
Old 10-01-2006 | 01:15 AM
MrCadillac's Avatar
yea, they do.... they are rather pricey too.
Matt,
even the OD alt pulley wasn't enough? Did he ever kill a battery? was his car packed with a bangin' system, or it simpley messed the ability to charge? Just curious.
Old 10-01-2006 | 07:35 AM
ABA383's Avatar
I've been using the ASP 23% underdrive pulley for 10 years with no ill effects...Maybe it was me, but the car seemed to rev faster with it...Dynos were not the norm back then so we did not do back to back tests, but it felt as though it was working...I dunno...I dropped .2 tenths with one on my old GN, so I figured that it would help an N/A set up...
The ASP balancer/pulley set up is the way to go if you want to use one...imho...
--Alan
Old 10-01-2006 | 07:54 AM
the_merv's Avatar
Mine revs up faster, that's one thing that everyone noticed when we were playing with it.
Old 10-01-2006 | 09:10 AM
MrCadillac's Avatar
how much does that none piggy back ASP run?
Old 10-01-2006 | 01:29 PM
buffman's Avatar
I think a smidge over $160
Cory he had a system but he never really used it much. it was out of the car more than it was in it..
Old 10-02-2006 | 05:11 AM
MrCadillac's Avatar
very interesting Matt... I woulda never thought it would happen. now I know.
Old 10-02-2006 | 01:15 PM
camzaro28's Avatar
Originally Posted by ToxicTA
You felt the revs go up quicker during normal acceleration? I think your trying to pull my leg now.
guess it would be called throttle response. just seemed as i didnt have to give it as much gas as before. seemed to climb quicker. dunno
all i know is i am having charging issues, and it seemed to have started within weeks of installing the pulley.
go with the ASP as someone else stated
Old 10-02-2006 | 08:18 PM
  #32
wrd1972's Avatar
Originally Posted by speed_demon24
Don't get a POS piggy back pulley that just adds weight. If you get one, do it right and get the ASP 23% pulley, it replaces the stock ballancer, its not a piggy back one.
I have had the March dually piggyback and I now have the ASP intergrated pulley. I really like the ASP pulley better than the March.
Either way I paid less that $75.00 for both of my UD pulley sets. Just look for a used set but I would not pay full price for new. There are very minor gains here.
Quick Reply: underdrive pulley question
