Poly Trans Mount
Old Sep 26, 2006 | 09:41 AM
ZFan88's Avatar
Default Poly Trans Mount
Ok, I installed this over the weekend...easy job and really takes care of the shifter bouncing around. Now I'm getting a clunk sound that sounds like it's coming from a little behind it.....driveshaft area? It happens when I shift or take off, when it's transfering a load. I double checked the mount and surrounding bolts to make sure they were all tight, which they were. I'm not sure what it could be as I can't check it while moving lol, any ideas?
Old Sep 26, 2006 | 10:09 AM
sleeperMULLET's Avatar
could be a u joint, check your driveshaft for excessive play
Old Sep 26, 2006 | 10:20 AM
TransAminal's Avatar
Check the torque arm. Its the huge metal piece that spans from the side of the transmission all the way to the rear. If the mount is broken or missing, it could cause a clunk.
Old Sep 26, 2006 | 10:39 AM
ZFan88's Avatar
I'll check out both when I get home from work and update. Thanks
Old Sep 26, 2006 | 02:50 PM
ZFan88's Avatar
The car's jacked up right now. Just made sure all the bolts around the trans mount were tight again. Checked the torque arm for any kind of play and it appears to be good. The rear part of the driveshaft isn't budging, but the front u-joint area has just enough play in it to barely move. I don't think it would cause a loud clunk sound though. I'm confused now. I would've expected to see something loose..
Old Sep 26, 2006 | 03:22 PM
ZFan88's Avatar
Anyone else had this problem? It's in the air now and I'm clueless...it's weird. Only happens when a load is placed on the drivetrain, ie. takeoff and shifting
Old Sep 26, 2006 | 03:37 PM
TransAmMan93's Avatar
this happedned to me but it was due to the nut unscrewed its self off of the poly trans mount. i put it back on with some loctite and havent heard anything since. the only other things that i could possibly guess would be the trans mount (the "c" bent support that supports the the end of the tranny where the drive shaft goes into or the thin metal sheild that goes under the driveshaft). thats all i could think of since the u joint and torque arm are secure. good luck with your troubles
Old Sep 26, 2006 | 04:10 PM
ZFan88's Avatar
It sounds like that would be the problem, it's what is confusing me. I re-checked all the bolts, even jacked the tranny up a hair and tightened things down to make sure. Same thing is happening when I drive it hard at all..
Old Sep 26, 2006 | 04:18 PM
ToxicTA's Avatar
Does this sound only happen once when the back end is squatting. I noticed recently that I have a similar noise what I found was that the rear end was actually digging hard enough to set it on the rubber snubbers on the rear end.
Old Sep 26, 2006 | 04:51 PM
ZFan88's Avatar
Ya, on a moderate take off and moderate shift you'll hear/feel it. It's coming from in front of the rear though. I just took it all apart and reinstalled it again taking my time, bout to go test drive....wish me luck lol
Old Sep 26, 2006 | 05:08 PM
ZFan88's Avatar
Same thing, damnit. What kind of an effect would bad motor mounts cause? I noticed when I get on it the shifter moves from the left to right quite a bit, making me think the engine has too much play and it's transfering back, causing the noise? ...
Old Sep 26, 2006 | 06:51 PM
Chaotic Firebird's Avatar
I have a similar clunk coming from my car, but I think it's the y-pipe hitting the tunnel brace [flimsy stamped steel peice behind the trans mount]. Bad motor mounts could cause excessive movement of the y-pipe hitting the floorboards and/or tunnel brace. I just bought an aftermarket tunnel brace, hopefully this will get rid of my clunk.
Old Sep 26, 2006 | 09:10 PM
the_merv's Avatar
Veteran: Air Force
I have a Poly Mount in mine, and it never clunked. The Eshaust does, yours might be doing that..
Old Sep 26, 2006 | 09:21 PM
ZFan88's Avatar
I only have a catback and the clearance is good from the exhaust. I can see the shifter moving left to right when I get on it. It only started doing this when I got the trans mount, the clunk sound I mean. I was thinking trying a new stock one or buying poly motor mounts as well?
Old Sep 27, 2006 | 09:36 AM
dhdenney's Avatar
I would probably say matching poly mounts is good advice. Transmission is gonna have less flex than the motor now. Whereas before the flex was about equal due to the stock mount material.
Old Sep 27, 2006 | 09:55 AM
ZFan88's Avatar
Well I just bought poly motor mounts and a torque arm mount while I was doing that, so I'll update after install. Thanks
Old Sep 27, 2006 | 10:04 AM
Definitely let us know how it goes.
I may do the same thing, my after installing my poly trans mount my car seems to get some minor torque transfer issues at lower RPM's, it starts to buck back and forth slightly like the engine is moving too much...
Old Sep 27, 2006 | 10:09 AM
ZFan88's Avatar
This is my 3rd Camaro so I'm used to noises and things moving around a bit
But the shifter will move around 2-3 inches left to right under a heavy load, which is too much play. The poly trans mount really stopped the 'constant' bouncing around of the shifter though and feels great until I get on it with the other problem
