Finally Finished-BRE Single Plane Conversion!
Old Sep 28, 2006 | 10:04 PM
SStrokerAce's Avatar
Ron,
I also noticed the adaptor plate for the new TB and the new powdercoat. I can get those adaptor plates for those TB's anyway but I'm glad you guys figured it out. The MAP sensor and all the vacuum lines look good as well.
On the last motor I built in house with one of those single planes thats where I put the FPR as well, the plumbing was a bit trickier than what you will run into, but over all that setup looks good! Thunder did a good job.
Bret
Old Oct 1, 2006 | 11:48 PM
Turbo_6's Avatar
Bret, I think they ended up making the adapter plate, but I'm not 100%. Shane and MADMAN have both been contributing to getting this thing running.
SLPHawk300, Yes it will fit. There was some modification to the underside of the hood and a small amount of modification to the cowl. It won't fit under a non-WS6 or SS hood though.
Old Oct 2, 2006 | 12:14 AM
BizZzatch350's Avatar
Moderator
Looks awesome, the Pontiac valve covers look sick
