Octane?
Old Oct 28, 2006 | 08:41 PM
  #41
GIZMO's Avatar
The funny part is that none of you guys know anything about gas or tune. The more that I read the more obvious it is.
Funny stuff.
Daren
Old Oct 28, 2006 | 09:21 PM
  #42
Honda Hunter's Avatar
Why did you guys dig this up anyways?
Old Oct 28, 2006 | 09:25 PM
  #43
the_merv's Avatar
Veteran: Air Force
I have mine tuned to run a point rich, it burned a Head Gasket cause it was lean. And the Pistons showed it by the burn pattern. I run 93 cause I am high-compression, and I don't want any problems with anything internally, and like stated before, it burns slower, so the Computer can adjust the Timing easier.
Old Oct 28, 2006 | 09:26 PM
  #44
GIZMO's Avatar
I dug this back up because I thought that it was correct to point out the good that Torco does for our sport and our community.
Good Luck,
Daren
Old Oct 28, 2006 | 09:54 PM
  #45
anaik's Avatar
Although lengthy here's some good info on gas.
http://www.faqs.org/faqs/autos/gasoline-faq/part1/
Old Oct 28, 2006 | 11:33 PM
  #46
Good Luck,
Daren
I had limited success with the addative. I blame the plugs I chose not the addative though.
