i got a plug problem, help me solve
Old Sep 28, 2006 | 11:34 PM
Taubr Unit's Avatar
Default i got a plug problem, help me solve
my 4 plugs on the pass. side are black as can be after 20 min. drive on new plugs. And the 4 on the drivers side looks to be running lean. The car drive good still, feels like it lost a little power but still drives good, and has a little rough idle a little. What you think is the problem. I got mid headers on it so i would assume it has newer o2's but if not they got 100k on um. Could i need new o2's or what?
left one is pass. side right is driver side
both new plugs with 20min drive time on them
Old Sep 28, 2006 | 11:39 PM
LS1Silverado05's Avatar
Did you change them yourself? Its almost like the passenger side didnt get changed. I know thats the side I would skip..LOL.
Old Sep 28, 2006 | 11:43 PM
Taubr Unit's Avatar
no, its real easy to change all my plugs. I did do all 8.
Old Sep 28, 2006 | 11:46 PM
Oh..yea you do have headers.. Yea man. Thats strange. I am curious to see what people give ya for info.
Old Sep 28, 2006 | 11:57 PM
the_merv's Avatar
Veteran: Air Force
Is that a pic of a new plug next to that used one, or one that was on the lean side?
Old Sep 29, 2006 | 12:19 AM
Taubr Unit's Avatar
left one is out of the pass. side and the right one is out of the drivers side............. both new plugs with 20 min of drive time on um.
Old Sep 29, 2006 | 12:30 AM
99S351's Avatar
Bad Trader (Louis H)
Hmmm... either your spark plug port holes are very dirty with carbon soot or its your injectors. Im almost sure its not a leaky intake valley or valve seal oil leak like I had because it would look like this
Old Sep 29, 2006 | 12:31 AM
buffman's Avatar
hey 99S351 your signature is too big. Max heigh 150 pixels.
What shape are your 02s in?
Old Sep 29, 2006 | 04:26 AM
MrCadillac's Avatar
also, what did the plugs before them look like? You might have a leak by the headers on the pass side, giving a lean reading to that bank? or does it not work that way?
****, that is very odd....
Old Sep 29, 2006 | 09:09 AM
tbsimmons's Avatar
Looks like either a dead O2, or a leak making the O2 show lean and dumping fuel.
100K in my opinion is to much on O2 sensors.
Old Sep 29, 2006 | 09:19 AM
Taubr Unit's Avatar
the plugs were BRAND NEW when i put them in. And ALL 4 plugs on the pass. side are black. And ALL 4 on drivers side are lean. I guess ill try new o2's and go from there.
Old Sep 29, 2006 | 11:46 AM
Camaro_freak's Avatar
+1 on a bad O2 sensor. That would very likely cause one bank to run richer/leaner than the other. Another thought is that you could have a vacuum leak on the lean side and the fuel trims can't compensate enough for it.
Old Sep 29, 2006 | 06:20 PM
Taubr Unit's Avatar
does anyone know anything about the MSD o2's? There $85 ea. as opposed to $65 ea. for OEM. Or are they just a selling gimmic.
Old Sep 29, 2006 | 08:09 PM
Matts94Z28's Avatar
Go delco
Old Sep 29, 2006 | 08:20 PM
buffman's Avatar
go delco they should be $44 a piece From DAL
Old Sep 30, 2006 | 12:56 AM
MrCadillac's Avatar
Acdelco! I think mine were about $50 each after shipping at gmparts direct. just becareful, they rape you for shipping.
Old Sep 30, 2006 | 09:10 AM
Taubr Unit's Avatar
i got a buddy that works at pepboys that can get um for me. I dont know the brand but there free, so beggers cant be choosey.
Old Sep 30, 2006 | 11:44 PM
MrCadillac's Avatar
they better not be bosch.... they caused surgeing issues in my 89 caddy. if they are free bosch's, put 'em on ebay and put the money twards AcDelco
Old Oct 1, 2006 | 01:00 AM
Taubr Unit's Avatar
yea, there bosch. Well ill see if that solves the problem. If so ill go from there.
Old Oct 1, 2006 | 02:53 AM
MrCadillac's Avatar
I wish you the best of luck... don't set the bar high.
