Head Ground
Old Sep 29, 2006 | 03:00 PM
Quick96ss's Avatar
Default Head Ground
There is a copper wire that is a ground to the frame and the drivers side head i dont know where it connects to the frame could some one please give me pics or the me what to do.
Old Sep 29, 2006 | 03:11 PM
foggedz's Avatar
There should be a bolt hole on the iner side of the drivers side frame rail for it. The bolt is one of the 10mm headed bolts that are all over the front end of the car. You dont need to ground it to the exact same place the factory did. As long as it is grounded and has slack for the motor to move around you should be fine.
