A couple of TH350 questions..
http://store.summitracing.com/partd...15&autoview=sku
1)is that all i need to have it rebuilt?
also, im gonna get a vig3500 probably or something similar to that TC.
2)Im not sure how to tell if i need a new driveshaft. Is there a way to tell like measuring it or something?
3) What im going to get is the rebuild kit, a new shifter and a stall. Is there anything else I need?
4) do I really even need a new stall?
Thanks to anyone who answers some of the questions. Thanks
2.If the th350 you get has a 9in tale shaft, and you are still using your stock rear end, you can use the stock drive shaft. If you have a stock driveshaft with a 12bolt, the drive shaft will need to be shortened.
3. Trans mount will have to be modified. New dip stick tube. Would probably be a good idea to change out the flexplate.
4. Im not the best to answer questions about converters, but I think that you will have to get a new one. If you have a A4 then the converter is made to lockup, and unless you spend alot of money you will not be able to lockup your converter with a th350. I swaped from a M6 to a th350 so I just bought a small bolt pattern th350 converter.
its just a summit rebuild kit thats like 125 bucks.. if you go to summitracing.com search th350 rebuild kit and its the 125 dollar one. Is there a way to measure the tale shaft or something?
