Bolt On's
id also go with an electric water pump and a 160 degree thermostat as well as a good opti or cap and rotor when you change your cam since all that stuff has to come off when you change your cam anyway. oh and we cant forget about a good tune.
get an electric waterpump...get a 160 stat tune, then weight reduction is your friend
I drove my car everyday to school, work, and werever i needed to go for 2 years.
4.10s, 3200 stall = great DD.
Tony.
not needing more than a 3000 stall, and 3.73's in a daily driver? that is BULL. A few guys I know have that setup with an even smaller B-body stock cam(190* duration at .050). Atleast 2 guys wish they had more stall. Anouther went 4.10's later and couldn't be happyier. And like stated, why buy parts twice? why buy a 2800 stall, just to go 3200 with a cam, and so on. you gotta look ahead. BUT, also note that some stalls flash stall higher than they are rated, by 300 rpms or so, so keep that in mind. BUT, this is IMO.
3000~ish stall
1.6 rockers
new valvesprings
3.73 gear is enough for me with a big car,should be great with almost 1000lbs less
with good tires and the right pcm tune it should run 12s pretty easy.
