Different brand of optis
un huh. I think thats what people fail to see. Yea, they are expensive, but they tend to be realatively problem free for 100k. Thats not to say they don't fail sooner, or are garentee'd to go 100,000. I know of caprice guys that put closw to 200k on stock opti's. and on the other side, some guys have killed them before 50k, and I'm sure some have been worse. I also wonder why the GM ones is considered junk, while this 2 month old MSD is a god, at almost twice as much.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Originally Posted by MrCadillac
I also wonder why the GM ones is considered junk, while this 2 month old MSD is a god, at almost twice as much. ![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
isn't the timing deal so you can retard/advance and cam and have the Opti be accrate still?
If you want to change timing on an LT1 you alter the timing tables in the pcm. That is a far better and more flexible solution.
Originally Posted by infinitebird
Because MSD is generally regarded as a reliable name in ignition products and their opti has many design improvements over the stock one.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
i have the MSD...works good so far....and like you said we'll have to see how well it does long term.
nobody knows if something is a bad or good product until they try it and put it to the test
Originally Posted by LT1-DAN
we will have to wait and see if all the improvements really make it last much longer then a stock one. as of right now it is just a high priced unit with a worthless timing adjustment. i know they had some problems on the first batch that came out. i cant wait to see how well they do long term. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
