Need Help Fast!!!!!
Old Oct 7, 2006 | 11:13 PM
the_merv's Avatar
Veteran: Air Force
I was always told that, and everyone I know has always done that. Don't know about any performance gain, but I have had no negative results.
Old Oct 7, 2006 | 11:15 PM
buffman's Avatar
what setting preload? Puts less stress on the valvetrain at higher rpms. I run 1/4 Turn
Old Oct 8, 2006 | 01:41 PM
METAL MANIAC's Avatar
Originally Posted by the_merv
Ok.. most of them are 5/8. What you do is tighten them down until the Pushrod stops turning. Then you go another half-turn. That is what you turn. Once they are there, you get a 3/16 Allen Key, and tighten the Allen Head screw in the center of the Poly Lock. That sets it in place.
I would agree with most of this, however, when dealing with poly locks it would be best to go a quarter of a turn then tighten down on the allen screw and then turn your nut another quarter of a turn..this causes the allen screw and the nut to make a more positive lock...I have had them work loose with the above mentioned procedure....MM
Old Oct 8, 2006 | 10:07 PM
camar0corey's Avatar
I'm mostly sure in the comp cam instructions for their rockers they tell you 1/2 turn. I installed them 9 months ago, so I can't be certain.
